Question about Electrical Supplies
Motor hangs will not turnover until hand turn flywheel
Motor hangs will not trunover until I hand turn the flywheelthan motor/starter works fine. It also kicks back when just about stopped and has now damage starter. How can I fix it from hanging on tdc?
  • 5,603 Answers
This CAN happen if your battery is weak or starter is damaged and the "Bendix" is not working properly.
Read up how the Bendix is supposed to work to understand the principle. Search Bendix starter on google.
We can only guess what brand and model you have.
Posted on May 17, 2010
Starter motor/engine turnover
Check the alignment of the starter gear when it engages the flywheel. It may be going in too tight, or at an angle. It could be binding the starter.
Mar 28, 2014 | Volkswagen Beetle Cars & Trucks
Stater problem 420 honda 4wheeler 2010
PULL THE STARTEWR AND SEE IF THE STARTER DRIVE OR STARTER BENDIX IS BAD IF YOU START THE MOTOR AND IT HANGS IT WILL CAUSE THIS PROBLEM GOOD LUCK
Jul 14, 2013 | Motorcycles
Engine won't turnover
It sound like the starter solenoid that forces the starter gear onto the flywheel, you need to replace the solenoid unit.
Mar 30, 2013 | Rear Right Window Regulator & Motor for...
One day my 1994 aspire will start fine the next it wont how can i fix this?
If I understand correctly the starter motor turns but does not cause the engine to turn over. If this is the case then the ring gear on the flywheel or flexplate is worn out, or the teeth on the starter motor are worn out. The starter gear does not engage the flywheel. With the starter removed the teeth of the flywheel can be viewed. turn the motor over by hand and look for worn spots; the gear teeth will be noticably shorter. If you find worn spots then the transmission will have to be removed to replace the ring gear. Another possibility is the starter is not pulling in correctly, thus the gears would not engage.
Nov 22, 2011 | 1994 Ford Aspire
Cub Cadet LT1050 lawn tractor won't turn over and start. Starter motor does turn, but flywheel doesn't turn very fast, and stalls each revolution at the top of the compression stroke. I can turn the...
three people i know plus myself have this same problem with this same model tractor. new starters and new batteries did not help any of us
May 06, 2010 | Garden
Same symptoms occur in vehicles from time to time. It was your 'hand turn the flywheel' that made me lean toward this diagnosis.
Although You have not supplied the make/model I can make a few assumptions. The symptoms you describe sound like a worn relay/solenoid supplying power to the starter motor.
When the contact surfaces are at the end of their usable life, less and less of the 'cold cranking amps' get past them. So instead of freely flowing to the starter, the power is bottlenecked.
Check what ever mechanism your generator employs to provide starting power.
If you found this to be useful, please take a moment to rate.
Best regards
Mike
Mar 26, 2010 | Electrical Supplies
1990 Volvo 249 DL Stater issue !
pull starter and clean, check stater solenoid, check all electrical connections
Sep 13, 2009 | 1990 Volvo 240
Put new motor in starter grinds when motor starts
may need a shim you can call a part store and find out for sure
Apr 03, 2009 | 1997 Chevrolet Cavalier
Electrical Supplies Logo
73 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
