Field collaps Bottom half is picture, but top half is blank, is on my Sony Trinitron KV-AR29M30A TV
  • nicvdwa Mar 31, 2008
    Hope you can help me with this problem, because no where i can find a circuit digram of my TV Please Help !!!!
    cant find a diagram for my Tv at all
    New Friend:
MAN/WOMAN I GOT SIMILAR PROB. HOWEVER I AM SHORT OF CERTAIN DETAILS. IT IS ALL ABOUT THE VERTICAL SECTION. THIS IS THE PORTION THAT PRODUCES THE FRAME. IC TDA8172 IS USED FOR THIS AMPLIFICATION. CHECK TYPICAL PIN VOLTAGES AND ASSOCIATED CAPACITORS AROUND. CHECK VERTICAL SCAN COIL IMPEDANCE. TRY FURTHER BACK, THE ACTION OF IC CXA2159S. I DO NOT HAVE ITS PIN CONFIG. I NEED IT.OUR PROBLEM IS HINGED AROUND ALL THESE AREAS.
Posted on May 19, 2010
SOURCE:
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY TV PICTURE WENT BLANK WITH A STRAIGHT LINE THRU IT
want to know wat straight line. 1.white line in the middle from left to right or 2.white line from bottom to top there is a big diffrence in these two lines if 1 then u have to check the cvertical section ,the o/put may gone bad if 2 then u have to check the scanning coil
Jan 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony Trinitron wega KV27FV310
Sounds like a problem with the vertical circuit. If yuo can solder and are comfortable with working inside the set, you may be able to repair this.
Keep us posted.
Dan
May 23, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Half screen picture
This is commonly caused by failing capacitors in the vertical deflection amp area and sometimes with the output drive devices.
An experienced TV tech can troubleshoot your set and service it for you.
Jerry G.
May 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Half Picture
I have seen this caused by 2 different problems. The vertical output IC could be bad but it is usually the CXA jungle IC that fails to cause this. Either way the set should be serviced by someone experienced in repairing Sony TV's.
Aug 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Ekse
