Question about Casio G-Shock GW300CA-1V Wrist Watch
I have a gw300 and the battery is dead and i am looking for a new battery.
Ebay: http://shop.ebay.com/idiotdoc/m.html?_nkw=Casio+G-Shock+CTL1616+CTL+1616+Panasonic+Watch+Battery]&_sacat=0&_odkw=&_osacat=0&bkBtn=&_trksid=p3911.m270.l1313
Posted on May 25, 2010
2 Suggested Answers
  • 51 Answers
SOURCE: i have a gw300 and the battery is dead and i am
buying battery is not a problem its resealing so your watch is water resistant.you need a watch repairer who has water resistant chamber that gives you a print out of the depth they simulated in the test,these are more acurate than the manual chambers some repairers use so always ask. the battery number on the g shock watches is on the battery so take the screws out of case back and be carefull there are a number of springs on movement that control alarms et its always a 3 volt battery 2025or2035 or 2016. but remember if you try your self you have AC the movement wich is like jump starting a car.get it done by a pro is my advice.if not blog again and i will go through the sequence for installing cell .
Posted on Mar 26, 2010
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem
Apr 22, 2017 | Tissot Watches
I just got it for Christmas, I keep it in the house when not in use. I wanted to use it today and it won't turn on ??
The battery is dead. Put a new coin battery in it.
You generally pop off the back and can see what you need.
You can even look at the instructions that came with it.
Jun 25, 2015 | Garmin Approach S1 Golf GPS Watch
Wrong date and time
When was the last time you replaced the battery? It might need a new battery.
Thank you,
Marcelo
Oct 22, 2013 | Casio Watches
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
How do i change the time on the gw300.. i no longer have the instructions
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Oct 04, 2010 | Casio Atomic-Solar Watch GW300
There is no display on the watch at all, like the battery is dead but it is less than a year old. Is there some combination of buttons to push?
mcdevito75 here, Sorry, but a watch battery that is less than 1 year old can still be weak or dead, You have to try a new battery first. Battery could have gotton loose, or have dirty contacts. Look for a small watch repair shop in your area. It"s possible you shut the watch off also, Press and hold the MODE button 2-3 seconds see if the display comes back.
Jul 19, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Mar 26, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Have timex watch had battery replaced and watch quit working, she had to use clamp device to instal battery
If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
Apr 26, 2008 | Casio Atomic-Solar Watch GW300
Casio GW300 (2608) battery replacement
Hey all. The charge provided by the solar cells on the watch only really extend the life of the battery. The total run time of a battery depends on how the watch is used... backlight requirements etc. The battery will be depleted and need to be replaced.
Here is a site that has good instructions on how to change the battery in your G-Shock watch.
http://forums.watchuseek.com/showthread.php?t=20217
If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
regards
Graeme
Jan 04, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
437 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
