Question about Music
With the novation xio 25. How do i alter the decay speed of the synth sound?
    President:
  • 1,138 Answers
Try this link:http://www.novationmusic.com/answerbase/en/ or http://www.novationmusic.com/support/xio/
Posted on May 18, 2010
How do I connect my GK3 equipped guitar to an Electric Piano or Synth ?
You cannot connect a Gk3 directly to an electric piano or synth. What you have to do is connect the 13 pin DIN connecting cable from the gk3 to the input on a Roland guitar synth unit like GR 20 or the GR 55 which supplies the desired instrument tones as required. The synth can be connected via 5 pin midi cable to an external synth to provide further tones...I personally have never used a keyboard to provide extra tones because I am a guitarist so only used synth modules and not keyboard ....remember also you need an amp or pa system to hear the sound output from the guitar synth module or external module.
Aug 30, 2015 | Electric Music
The key sounds are flat not intune
You did not mention the model or year, but some models have a global detune setting available (read manual, download after Googling) and it is possible that has been altered from 0.0 to some other plus or minus cents. Other models of keyboards may have a tuning potentiometer on the back. If it is a very old analog synth, then any oscillator pots might need trimming and capacitors replaced (such is work for a keyboard tech).
Aug 11, 2014 | Roland Music
Can a Korg CX3 Organ 61 keys be compatible with the RolandFantom XR module?
Hi, from what I can tell you cound plug your CX3 into the synth module with a 1/4 inch patch cable and run the audio through it, however I think you will be quite limited in what you can do to modify your sound.
Where the synth really works well is when you feed it digital input data. For you to be able to do that your CX3 would need midi outputs and while I don't have one, I looked it up and can see that the CX3 is too old and does not have midi capability.
Midi (musical instrument digital interface) is a common language that allows musical devices such as your fantom to communicate with other devices. A keyboard with midi running into a synth is in essence just a control surface, a way for you to input data into your synth module, it is making no sound itself, but rather outputting digital data into your synth which in turn generates the sounds you want it to. There are allot of keyboards out there that are only for this purpose and are simply controllers. For example, M-Audio Oxygen 61 - 61-Key USB MIDI Controller. I'm afraid your CX3 is just too old to be able to do this, however, I imagine some of the sounds that thing makes are very vintage and good, and modern synthesizers often times just cant reproduce that (though they are getting batter all the time). Hope that helps :)
Dec 20, 2013 | Music
Keyboard won't play
Try: turning off keyboard and restarting the computer.
Start up Novation until completely loaded.
Switch on keyboard the set id ports....worth a shot(?)
Keyboard communication can be temperamental when interfacing with computers. Especially when dealing with audio problems, latency problems, inputs and outputs.
Follow the directions specifically in the Novation Manual...it only takes one wrong step to stuff the whole thing up ! :)
Nov 26, 2013 | Novation Music
Casio pg380
My Casio PG380 Synth Guitar...It lights up but no sound on the Synth..Any ideas..
Mar 13, 2012 | Music
Do you need a computer to use the Novation UltraNova 37-Key Analog-Modeling Synthesizer
The Keyboard comes with inbuilt sounds (Approx 300 Presets and 200 user patches), so you can play it Live without a computer by simply taking AUX outs and it has a wall power supply adapter. You can also connect it to your computer via USB for additional sounds through VST instruments and Plugins. The USB also powers up the Keyboard without the adapter. Hope this helps.
Jun 06, 2011 | Novation UltraNova 37-Key Analog-Modeling...
Hello To whom it may concern,Thank you for your assistance Ive had the Xiosynth for about 4 days now,and the problem that occurs is that the console's programs and led's go all wonky and...
Since you have had this only four days, exercise your warranty rights immediately. If you have bought this used, it is likely you have bought somebody else's problem.
Apr 04, 2011 | Novation Xiosynth 25 Midi Controller...
Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Aug 07, 2008 | Korg Mini Kp Kaoss Pad
Music Logo
74 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
