Question about SanDisk Sansa E280 MP3 Player
Wont go past the sandisc logo fades to white the logo comes up again what can i do. Have removed the battery but problem continues
  • 593 Answers
Try and reset the player, see these tips posted here on this site . Sansa Mp3 player frozen? How to reset and
See also these other tips posted here ...
Sansa View: is not recognized by my
How To Download MP3's To My Player.
Solve your MP3 Player Connection Problem.
Posted on May 17, 2010
Vizio e322ar won't turn on
My Vizio E322AR White Vizio Light comes on when plugged in, then slowly fades to "Off". I unplugged and replugged - same. I held down the power botton on the side, and plugged in... same. Vizio light comes on (White) and over 5 seconds or so... fades out to nothing.
Remote doesn't do anything, buttons on the side don't do anything.
Going to pull the back off and look for bad Capacitors, and test fuzes for continuity. Wish me luck ... will report back later with results.
Feb 21, 2014 | Vizio E322ar
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
Feb 03, 2014 | Toshiba Tecra R850 Series Black Notebook...
Samsung s5570 is stuck on the samsung logo i want to know if it fixable
My handset ran out of charge and when i had recharged it and tried to power up my phone, it went to the flashing samsung logo and wont go past it. I tried taking the battery out for an hour, replaced it and powered on again and its still sticking at the samsung logo. Can it be fixed. help me sir.....
Mar 26, 2013 | Samsung Galaxy GT-S5570
Wont boot past toshiba logo
Unplug the AC adaptor, remove the battery, then press and hold the power button down for a minimum of 30 seconds. Now replace the battery and see if it powers up. If not repreat the process but this time leave the battery out and only plug in the AC. If it still doesn't power on repeat the process again and this time replace the battery and plug the AC back in. If it still doesn't power up it's time to start checking the hardware. Remove the ram and try it with only one stick. You might need to try each one individually to see if either works. If that doesn't help remove the hard drive and see if it will post to the Toshiba screen. If that doesn't help you'll probably need to take it to a service center.
Nov 25, 2012 | Toshiba Satellite L775-s7352 Notebook...
My samsung sch-u485 keeps getting stuck on the verizon logo as i try to turn it on and thats where it gets stuck
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 02, 2012 | Cell Phones
My nokia x3 wont start after showing the nokia logo, blinked 4 times with white screen and its goes off.WHY
Remove the battery and the SD memory card, check the card for corrupt/virus infected files that have corrupted the software. Now have it scanned on your PC and remove/format the card.
Reset to the phone and check , if the fault comes back then the software must be installed on the phone. have this done at the Nokia care/support center.
Jan 17, 2011 | Nokia X3 Cell Phone
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
Oct 23, 2010 | Nokia 3110 Cellular Phone
White screen
Any answers to this,... I have had mine for 3 weeks and now can't use it!!! Due to the white screen HELP!!
Jun 15, 2008 | Nokia e65 Cellular Phone
Sansa m240
Hi. I'm having the same problem with my m250 and am concerned, since I've only had it for a month. Nothing I do, including removing the battery, hooking it up to my computer again, or holding the power button down for a long period of time works.
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
102 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
