Are you using the correct tape? If you try and use an LTO3 or LTO4 tape then it will just eject.
Does the drive make a clattering sound when first turned on and it goes through its POST ?
If the answer is YES then the drive has had a damaged tape loaded into it and the drive now needs repair.
Goto
www.tape-drive-repair.com for repair or replacement options as these are quite inexpensive these days
Also try inspecting your media as per the guide here.
http://tape-drive-repair.com/tools-and-information/lto-media-inspection-guide/If you find any damaged tapes then make sure to throw them away as should you reload these tapes they will go on to break your LTO drive again.
can i fix this error???
