Question about Canon MultiPASS MP370 All-In-One InkJet Printer
Printer problem Hi i have a MP370 canon series printer. its not working properly it thinks its printing it sounds like its printing but when it comes out its blank, and the ink is full, what can i do please!!!! ?
  • 20 Answers
This may sound like a stupid question (and if you think so please don't be offended) but it is a problem I have ran into in the past.
The ink cartridges come with a little tab or piece of tape on the bottom of them, have you check to make sure these have been removed? If they have then try to run a diagnostic on the printer (in the software that came with the printer), check print head alignment, try cleaning the print heads. If none of these work let me know.
Posted on Mar 31, 2008
SOURCE:
Is MP370 - Windows 7 compatable ? I cannot install
Yes, it is Windows 7 compatible. You can find the drivers for the printer at the link below. Just download and install the driver for your computer and the printer should be installed. If it doesn't install that way open up control panel, go to devices and printers, go to add a printer, choose local printer, use the default port and click next, choose have disk and select the drivers that you just installed, then just click next through the rest of the wizard. Just make sure you can print a test page.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/multipass_series/multipass_mp370#DriversAndSoftware
Apr 10, 2011 | Canon MultiPASS MP370 All-In-One InkJet...
I replaced the ink cartridge and sill does not print properly
you have to take it so that they could fix it because i think there's something wrong with it from inside ?
Nov 20, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
New ink and power to printer, but will not print on paper
how about the program or driver is installed properly? if installed properly open it then check the board of printer maybe it has something wrong inside why not printing..
Sep 14, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Hello there, i have a canon MP370 which i have been very happy with and had no problems,however the machine when it prints now all the colours are very faded and banding occurs right accross...
Check your cartridge first and take a look if it is not running out of ink,try replacing it with a new one then on your printer maintenance do head cleaning,then print nozzle check to see which color has a problem,if it doesn't change try to look for chemical solution that are being use to clean print head. soak the print head,dont touch the head with your bare hands or anything hard its sensitive.
Sep 12, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Printing problem with canon mp 370 printer
THE COPY OR PRINT NEEDS TO BE RESET, THE COPY OR PRINTER THINK YOU INSTALLED THE OLD CARTITAGE DID YOU REFILL THE INK ONLY, THIS MACHINE WILL NOT EXCEPT A USED CARTIASGE BUY A NAME BRAND
ROD
Feb 03, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Error waste ink tank near full
This page gave me a solution, try it.
Let me know if worked for you as for me scoring this solution. Thanks
Jan 30, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Mp370 driver dowmloads
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 08, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Canon Multupass C3500ex
HI
Visit already comes with drivers for the MP370 installed so just plug in your printer and go to contraol panel then printers and your image class mp370 shuld be there and you then set that as a default printer.
Oct 16, 2007 | Canon MultiPASS MP370 All-In-One InkJet...
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
98 people viewed this question
Clive
Clive
old marine
old marine
Ekse
