Question about Exercise & Fitness
Weider Crossbow Platinum The weight resistance needs calibration 20 lbs feels like 100 lbs. How can I fix this?
    President:
  • 832 Answers
ADJUSTING THE RESISTANCE When the resistance setting changes, the motor will be heard. To prevent damage to the motor, do not pull any of the cables while the resistance setting is changing. If a cable is pulled, the words RELEASE HANDLES AND READJUST RESISTANCE AS DESIRED may appear in the main display on the console.If this message is displayed repeatedly but no cable is being pulled, there may be too much tension on the Upper Cable . Adjust the tension as described below. To decrease the tension on the Upper Cable.turn the two 3/8” x 38mm Tension Screws twice,counterclockwise. Select the desired resistance setting.Repeat this step if necessary.CLEANING THE BAR GUIDES Over time, dust may build up on the Crossbar Guides , causing a squeaking noise as the resistance system is used. If this occurs, wipe off the Crossbar Guides with a damp cloth and a mild, non-abrasive detergent. Do not use solvents.
RECALIBRATING THE CONSOLE To recalibrate the Console , first plug in the resistance system . Plug the indicated end of the Transformer into the Back Mech Cover . Plug the other end of the Transformer into a 120-volt outlet. All indicators and displays on the console will flash once; the console will then be ready for use. The motor may be heard while the resistance system calibrates itself. Important: Always plug in the transformerwhen using the resistance system., press and hold the NEXT button and the MOTORIZED WEIGHT ADJUSTMENT + button for five seconds. When the buttons are released, a number will appear in the REPS display. Press the NEXT button again, then press the MOTORIZED WEIGHT ADJUSTMENT + button; this will start the recalibration process. This may take a few minutes as the motor moves between the lowest and highest resistance settings. When the motor finishes, unplug the transformer from the 120- volt outlet.The Console will be recalibrated. Use the resistance system as described in the CONSOLE
Posted on May 18, 2010
Weider Platinum xp600 won't change weight
I just finished fixing this exact problem on my XP600. I also could increase the weight, but not lower it. Both wires (grey and orange) were cut from the lower limit switch (it's in the upper right corner). The way the harness was jammed into the unit, it broke the wires. The limit switch fell apart as I was taking it out, so I soldered the grey (there's two) and the orange wires together. The display now works properly. Because the switch is now bypassed, I just have to be careful and not drop the weight past 15/20 lbs. If you raised the weight when the display wasn't reading right, it will reset once you increase the weight to the max. Then you can decrease and it will read the right weight.
Jan 05, 2014 | Weider PLATINUM XP600 Console
I just bought a used machine and the weight adjustment is inaccurate. I have to put it up to over 200 lbs resistance in order to get maybe 40 lbs despite what the machine reads. Is there something I can...
If you find the manual (quick online search) on page 23 there is a section under "RECALIBRATE THE MACHINE" .
Basically: Plug it in. Hold down the "Next" and "Resistance +" buttons together for 5+ seconds and release; some text will appear on the main display. Press "Next" again followed by pressing the "Resistance +" button again. The system should 'calibrate', you'll hear it moving thru the resistance lowest to highest (or vice versa). After it finishes it beeps or displays or both, unplug the system. When you plug it back up hopefully it fixes the problem.
Aug 18, 2013 | WEIDERFITNESS.COM Weider Platinum Plus
Hi, i am looking for a weider platinum exercise tape and or manual i have owners manual
The best source I can recommend is that you contact Weider Fitness and see if they such material. Since it was design to compete with the Blow Flex and they have basic exercise movements that both utilize. I have seen some Video off of YouTube even though they are 3 to 5 minutes in length it will give you a starting point.
May 29, 2010 | WEIDERFITNESS.COM Weider Platinum Plus
I have a weider crossbow platinum
Hello there, If you go to iconservice.com they have contact information, manuals and just about any other information you may require for your Crossbow.
Fyi the first thing I would check is the power supply itself to be sure it is putting out the correct voltage.
Good Luck! Tim
Jan 29, 2010 | Exercise & Fitness
Need excercise chart for Weider Crossbow Platinum. Available?
you can order a print here:
http://www.zazzle.com/weider_platinum_excercise_chart_poster-228106828410296215
or you can download it here:
http://www.mediafire.com/?5dzm31drljz
Oct 09, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
I have a Weider Platinum crossbow and the resistance isn't setting properly if at all. Is there a simple solution that I can do to fix this?
This is a common problem with this machine, the wiring inside the back. Mine was broken too, it was just a loose wire, but the stupid wire is so inside a protective case, you have to take the whole machine apart to be able to reach it.
You'll need a technician to come to your home. Call Icon to get a reference.
Jul 14, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
I have a Weider Platinum XP800 Crossbow that will not start.
I had the same problem. Take off the black box at the base and check to see if any of the wires broke lose from the connectors, mine did. One pair of wires was alot shorter than the rest, so when the previous owner disassembled the crossbow he lifted the unit too far before disconnecting the wire connectors thus braking the two wires from the connector. Simply remove the remaining wire bits from the connector with something sharp (unplug machine from the wall). Then take the broken wires and push them down into the connector terminals with a butter knife. The terminals will cut through the wire insulation and make a contact with the wire. Problem solved.
Jun 14, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Weider Platinum Home Gym - Cable Motor Stopped and Controls Blink
My son received an old Weider 8515 weight machine from a relative. The cable was worn and broke. Where would I find a replacement cable?
May 19, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Weider Platinum Crossbow is locked up.
i have the manual, to recalibrate the machine press and hold the next button and the motorized wieght adjustment+ button for five seconds. when the buttons are released, a number will appear in the reps display. press the next button again, then press the motorized weight adjustment+ button: this should start the reclaibration process. i am lucky i bought the machine in 10-2004 and it has a ten year warrenty. it isn't working it happened before and they had to replace the motor. if it works remembe to unplug the machine when not in use. it is a great machine to get in shape with. you just have to use it.
Mar 27, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Exercise & Fitness Logo
403 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
