Question about Samsung SF-340 Plain Paper Inkjet Fax
SAMSUNG SF 360....connects but doesn't send
I have a new SAMSUNG SF 360 that most of the time dials, connects for a short period and then doesn't send the fax....occaisionally it works but only 1 out of 8 . Also sometimes it receives and other times not. Is this the fax or the phone line?
    President:
  • 2,072 Answers
I Strongly suspect phone line.
If is it a DSL line you may need to filter is. If it is a digital line, then you shold switch to analogue.
I would start by just replacing the phone cord between the machine and the jack.
My other question is, are there any other devices plugged into the same phone line with the fax machine. A credit card reader, an answering machine? If so try removing them and see if there is some problem with a shared line.
But more then likely, you have a line with static, a bad groung. Low phone line voltage, current. some other line issue is very possible.
Suspect strongly a phone line issue
Posted on Mar 31, 2008
How i can print any file from a pc to sf-360 ( my windose xp )
The SF-360 does not have a printer functionality I'm afraid, only the SF-361P and SF-365TP can be used as printers and have a socket to connect to a computer
It is theoretically possible, if you have a faxmodem in your PC, to send a fax from the computer to the printer, but this is rather complicated and the print quality would be poor (like a fax).
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Samsung SF360 Plain Paper Inkjet Fax
Ferrari 360 Fi spider instrument back lighting doesn't work, fuses are checked ok , what to do?
Time to open up the cluster and check for bulbs being out, or a shorted wire. Do the dials and gauges still work, and is there a dimmer on your model. I remember the older Ferrari's' having a dial type dimmer, you may have moved it to the lowest setting that would make them appear off.
Jul 12, 2011 | 2004 Ferrari 360 Modena
I have lost my fax machine users guide booklet can i get one for samsung SF 335 T
I have this manual. LBrown18062@hotmail.com. Please put SAMSUNG SF3100 as the subject. List of Features
This machine was designed using the latest technology. It is a full-featured, high-performance machine that not only meets, but exceeds industry standards. The following is a list of its many exciting features:
Features for both SF-3100 and SF-3100T
• Inkjet printing on plain paper
• 14.4Kbps high speed faxing
• 80 page holding memory
• Seven language display and report; English, German, French, Italian, Spanish, Portuguese and Dutch .
• Stand-alone, full-function fax machine
• Convenient 99 pages desk-top copier
• 15 page Anti-Skew Document Feeder
• Five One-Touch and 50 Speed-Dialing locations
• Group Dialing to eliminate repetitive dialing to the same multiple destinations
• Four reception modes; TEL, FAX, AUTO and TAM1
• Broadcasting to send the same document to multiple destinations
Feb 05, 2011 | Samsung SF-3100 Plain Paper Inkjet Fax
Need to add new fax numbers to short dial
Copy this link, and you can download a copy of the manual: http://www.samsung.com/uk/support/download/supportDown.do?group=printsolutions&group_cd=&type=printsolutions&type_cd=06010000&subtype=colourmultifunctionprinter&subtype_cd=06010100&model_nm=SF-750&dType=D&mType=&model_cd=&menu=download&menuLink=%2Fsupport%2Fdownload%2FsupportDown.do&prd_ia_cd=06010100&disp_nm=SF-750
Jun 15, 2009 | Samsung SF-750 Plain Paper Laser Fax
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
Samsung SF 3200
The person you are sending to has a busy phone line.
Call your cell phone from the fax machine to test.
Oct 24, 2008 | Samsung SF-3200 Fax
Sf-5100 issue
Kindly check the setup. Before anything refer to manual and check that you are getting a dial tone for sending in a telephone set.
Best Regards
Rafique
Mar 27, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Can't get the machine out of "broadcasting mode"
have you tried to see if paper is jammed in side of the fax manchine this will prevent it send/receving faxes .
follow your manual instructions for this .
you could also contact samsung on the number 08707267864 8am-8pm.
riz.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-340 Plain Paper Inkjet Fax Logo
172 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
