Question about Xerox XL-775D (Black) 17" LCD Monitor
The monitor take a few minutes to start up, or the
The monitor take a few minutes to start up or the picture will flick off and on when it has started up. Any ideas as to the cause of this?
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
SCREEN TURNS OFF AND GOES BLACK
The picture board on your monitor is faulty or bad, since it goes black after few minutes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board or any service center because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | HP w1907 LCD Monitor
The monitor take a few minutes to start up, or the picture will flick off and on when it has started up. any ideas as to the cause of this?
I will assume that it does the same when you hook this monitor to another PC. First place to look inside will be the power supply section, look for caps with bulging top/seal, post back what you see so we can guide you further. See example of failed monitors due to bad components: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | Xerox XL-775D (Black) 17" LCD Monitor
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
I have an older admiral tv. The picture goes in and out.
check the terminals of the yoke..it might have a loose connection..try to resolder...otherwise you need to check both horizontal and vertical output..
Jun 14, 2009 | Televison & Video
Compaq 7550 screen issues
Your monitor is having thermal problems. Some part in the horizontal circuit is changing value as it warms up, and you're seeing the effect. It's possible to troubleshoot this kind of problem by using spray chiller to cool down parts and find the culprit, but labor and parts would probably mean you're better off just replacing it. New LCD's are quite cheap today, and you'll gain extra space on your desk if you get one.
Dec 28, 2008 | HP Compaq FS 7550 17" CRT Monitor
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Xerox XL-775D (Black) 17" LCD Monitor Logo
129 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
