Question about Vicks V3100 1.2 Gallon Humidifier
I have a Vicks V3100 and dont know how to put it together or if I even have a filter. I do not know what the filter looks like
    President:
  • 1,015 Answers
There is a Wicking Filter that is also the same media that creates the humidity. This filter looks like rolled up paper media(like for a swamp cooler). This filter installs at the back of the unit with the water resevoir removed. The water then is absorbed by this media and as the air passes through it humidity is released into the air. The Wicking Filter will need to be replaced when the performance of the unit decreases and the material becomes hard from mineral deposits. There is also a Protec Cleaning Cartridge that looks like a small plastic ball with a stem on it. Inside this cartridge are softening agents that remove hard minerals and extend the life of the Wicking Filter. The Cleaning Cartridge is just simply placed inside the water resevoir. To prolong the life of the Wicking Filter and unit make sure to use clean and cool water. Distilled water will work the best if available. The harder the water you use the more the unit will need cleaning due to hard water. When the unit becomes clogged with diposits you will need to run a solution of vinegar and water through the unit to clean it. If you use distilled or filtered water(reverse osmosis) then the unit will rarely need cleaning.
Posted on May 16, 2010
How much are the filters for this
http://www.filters-now.com/products/uvk.html#UFWF2=UVK
THE FILTERS ARE $8.99 PLUS SHIPPING
TRY HOMEDEPOT OR MENARDS SO YOU WONT HAVE TO PAY THE SHIPPING COST
Mar 20, 2010 | Vicks V3100 1.2 Gallon Humidifier
How do i take apart and clean my Vicks V3100 cold air humidifier?
couple of screws on the bottom, but why take it all apart when you can probably run vinegar through it and let that do the work, smells a little, so maybe on the porch...
Feb 27, 2010 | Vicks V3100 1.2 Gallon Humidifier
Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Feb 09, 2010 | Vicks Humidifiers
Where does the filter go. I have no instructions or pictures of the filter in place
Go to www.kaz.com
They have the manual (you can print) and it shows a view of how everything assembles. The also have replacement parts.
Hope this helps.
Jan 08, 2010 | Vicks V3100 1.2 Gallon Humidifier
Vicks V-3100E Filters
Here is a site that stocks the filters you require, but needless to say it is main order.
http://www.healthcare4all.co.uk/vicks-filter-aca3e-v3100-p-330.html?osCsid=168dab22ab1bfeb75a4095d3d6e51127
Vicks Kaz Filter ACA-3E for V-3100
Availability: In Stock (for immediate despatch)
[ACA3E]
£9.79
(incl. VAT at 15%)
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Vicks V3100 1.2 Gallon Humidifier
Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Nov 28, 2008 | Vicks V3100 1.2 Gallon Humidifier
Vicks V3100 Humidifier
http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=285ef863f85db2982e6f095560687917
Sep 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Missing part
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is a link to the manual for the humidifier you bought.
It shows how everything comes apart and how it all goes together with the filter.
Hope this helps.
Good Luck.
Apr 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Vicks V3100 1.2 Gallon Humidifier Logo
296 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
