Generic security locked usb device
External hdd has a password and cannot be viewed from my computer xp/vista os
2 Suggested Answers
AnwarH
  • 107 Answers
SOURCE: generic security locked usb device
Need to contact the HDD manufacturer. They Will reset the Pass Word. However the data in the HDD will be Lost
Posted on Mar 26, 2010
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
Apr 04, 2017 | HP 250GB Pocket Media Drive 250 GB Hard...
New Hard Drive purchased Reloaded OS (XP Home
go to your device manager under xp its right lcick my computer-properties-devicemanger. check on the bottom your usb settings if there is a red or yellow marking you may need to re-install your chipset drivers. or download generic usb generic drivers. let me know if this helps
Mar 17, 2011 | Dell Inspiron 1521 Laptop
I was given a 160 GB simple tech external hard drive and pluged
You don't really need a manual, it's simply a normal USB HDD you just plug it into a USB port. If OK, you will hear a "Bong Bong" and the OS will detect and install drivers, then the device will show up in My Computer, as a simple HDD, just use it as a normal drive.
May 11, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Mar 26, 2010 | Computers & Internet
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jun 20, 2009 | Western Digital Passport 320GB External...
Hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My external harddisk is not detecting
hi kiran,
If you are using Windows 98 then you have to istalled driver for your external USB HDD.
If you are using Windows XP/Vista then the masstorage drivers for USB HDD is allready installed in your system, as it comes with the OS.
Some time due to conflict or bad contact your system might not read the USB devices:
  • Be sure that switch is on (if there is any switch in USB HDD).
  • Try to check the connection.
  • Try in different USB port.
  • Also check the USB cable is good.
If still no success try to use in another system and let me know your feed back.
Thanks
Iqbal
May 21, 2008 | Seagate Barracuda 7200.7 200 GB Hard Drive
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
