Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson r265 I have just put new cartridges in my printer but the red light won't go out so the printer won't work at all. The green button is flashing and the red is stable....any ideas anyone please.
  • 1 more comment
  • EHCR Sep 21, 2008
    Both lights (green Power and red Ink) flashing, from the first time I tried to switch it on.
  • busapuppy Oct 08, 2008
    i have the same problem with my original printer. Epson has now sent me 2 replacements and they are both doing the same thing. Dont; know what to do.
  • Anonymous Dec 30, 2008
    basically eveery single light is flashing, there's an E in the copy bit and ive tried to scan and copy but its not working all it does is print. The light if the scanner is working and ive uninstalled and installed about three times now
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a28
Posted on May 24, 2009
6ya staff
SOURCE:
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson R265, new ink cartridges fitted correctly but red light stays on
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 21, 2010 | Epson Stylus R265 InkJet Photo Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
U can find resetter (SSC Utility or R265 Adjusment) at indoreset.blogspot.com. Reset the waste ink counter.Good luck.
May 29, 2009 | Epson Stylus R265 InkJet Photo Printer
Service ink reset error epson R265
Try to find out how to completely reset your machine through your manufacturer
Feb 27, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson R265 Ink pad full
I have problem with r265 Epson. I installed new ink cartridge from epson but the printer could not recognize it. I installed SSC Service utilitry, but the programme could not recognize printer at this status. What can I do?
Nov 03, 2008 | Epson Stylus R265 InkJet Photo Printer
Red lights flashing on printer
how many of the lights are on?
ushally turning the printer off for 5 mins or so ushally works.
have you changed anything inside your printer lately? ink ect.
Aug 13, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265 printer
ive had this problem too try putting the pollystyrene that holds the top of cartridge during transit back in when inserting cartridge into printer i found this worked for me
Feb 01, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
163 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
