Question about Optics
Disassemble the eye pieces ww 2 german 10 x 80 45 degree flak bin
Remove and disassemble the eye pieces from the main body
  • 3,186 Answers
NEVER disassemble an eyepiece. This usually voids the warranty and the optical surfaces inside NEVER get dirty.
Posted on Jun 01, 2010
Model 440639. How can I disassemble to lubricate the seals and remove the cartridge?
sorry but I can not seem to find a picture of it . please post one . it might just be one of those that the cap unscrews to get inside to the cartridge .Strap wrenches work really well on them
Oct 02, 2015 | Blanco Plumbing
Replacing a oil tank
Highly recommend taking it to a small engine repair shop. disassembly of the chainsaw body is pretty difficult, be very careful not to get hurt by prying too hard while prying apart the 2 main pieces of the saw body.
Aug 10, 2012 | Garden
Recently lost gun in water for a moment, Now scope gets fogged inside. Is there anything I can do to stop it? It a fairly new scope.
Your scope may not be hurt if water has not caused any rust yet. Things you will need, (1) hair drier, (2) Vaseline, (3) large clear plastic bag, (4) gas from a paint ball gun canister or similar type of inert gas you can use. Remove the eye piece, and shake as much water out as you can. Use the hair drier and heat the tube up, not too hot but warm, to dry the inside as good as you can, keep after it, shaking it and heating it. Once you feel all the water and moister are gone. Put a good amount of vaseline on the threads of the eye piece. The put the scope, the eye piece in the plastic bag. Use the paint ball gas and inflate the plastic bag, tie off the bag leaving room so you can screw the eye piece back on the main tube. Leave the scope in the bag for a few minutes before you do screw the eye piece on letting the gas fully get in the tube. The gas will give a bit of positive pressure inside the tube, Will displace any other air that will have moister in it. Keep the inside from fogging back up. The vaseline will help seal the gas inside. Hope this Helps Fix Ya up.
Apr 25, 2011 | Bushnell Sportsman Rifle Scope 3-9X 40...
The threaded attachment between the eye piece and main body is loose and will not tighten without coming undone. Threads must be worn.
Televue will repair this. Contact them here:
http://www.televue.com/engine/page.asp?ID=2
Their contact phone number is at the very BOTTOM of this web site page. Call them.
Jun 26, 2010 | Televue Pronto (180 x 70mm) Telescope
Replacing gears
you have to disassemble the tool completely. Remove chuck, remove battery, remove all screws holding body parts together, remove one side of body. Now you can see motor and gear box. Pull out both of them and twist gearbox a bit (just few degrees or millimeters) if it goes, then just pull gear away from the motor. Be carefull, some gear parts may drop of, so hold gearbox down and motor up. Juraj
Jun 04, 2010 | Makita 18V 1/2"CRDLS Drill Kit
if you like give me a call..to hard to explain how to take apart typing...5088330650...larry
Mar 26, 2010 | Optics
I have a Hotpoint HSS25IFMD WW sise by side
A thermistor is a 2" torpedo looking piece with 2 wires attached to it . The defrost bimetal , a 1" round aluminum piece , snapped onto the coils , with 2 wires , should be replaced when replaceing the heater . This bimetal could be the problem . To test the defrost system , remove the main control board cover . The blue plug with 3 wires to it needs to be connected . Looking at the plug , the wireing will look like this : l l l . Lets call the terminals 1 2 3 . Useing a piece of insulated wire with both ends stripped , insert one end into terminal 2 and the other end into terminal 3 . The heater will come on if both the heater AND bimetal are good . If you put a new heater in and it wont come on , and you do this test , then the bimetal has to be bad . If your terminology is correct , you have 2 thermisters in the freezer . One on top of the coils ( evaporator sensor ) and one at the bottom by the drain pan ( freezer temp sensor ) . Wouldn't hurt to replace both if you replaced one .
Aug 06, 2009 | Refrigerators
The main eye piece is missing the lens.
yes you can..most brands of telescopes will fit others as far as eyepieces go..so if you call bushnell@18004233537 im sure they can help...good luck....... lary@reichinstruments.com
Oct 31, 2008 | Tasco Astronomical 302675 Telescope
Kodak EasyShare Z612 Digital Eye piece
you have to take off the back plastic part of the camera carefully. I snapped it off carefully. Then you take off 2 black screws at the eye piece and insert the rubber. screw back together. snap plastic back on and screw in all the screws. have fun!
Jan 09, 2008 | Kodak EasyShare Z612 Digital Camera
Optics Logo
57 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
