Question about IBM Microsoft Windows XP Professional for PC
How can i speed up my pc? - IBM Microsoft Windows XP Professional for PC
    Problem Solver:
  • 5 Answers
There are several steps you can perform to help speed up your PC. Be aware that your performance is ultimately limited by your hardware, but these steps should help.
1.) disable unneeded startup programs.
To do this, you need to open the System Configuration Utility. Hit the Windows key on your keyboard and R at the same time. This will open the run box. Type msconfig and hit ok. On the utility, hit startup in the top right. Then in that section, hit disable all in the bottom right. Go through the list and enable any startups for your Antivirus software and anything that says Operating System. If you have specific software that you want to start when you boot up your computer, also check them as well.
2.) Run full virus scans.
Often, slow speeds are caused by adware and spyware. There could also be other malicious software. I recommend Malwarebytes and Superantispyware, both available for free.
http://malwarebytes.org/
http://www.superantispyware.com/download.html
3.) Reboot your computer after both scans are complete. This will ensure that all threats were removed properly.
4.) Clean your browser.
I use CCleaner to do this.
http://www.piriform.com/ccleaner
5.) Run a disk defrag.
There a couple of ways you can do this. The first way is to use the built-in utility. Go to Start, then All Programs, then Accessories, then System Tools, then Disk Defragmentor. Alternatively, and my preferred method, you can use 3rd party software. My recommendation is Defraggler.
piriform.com/defraggler
This entire process could take several hours, so be sure you have the time to spare. You should not perform other tasks on your computer until the entire process is complete.
Posted on May 16, 2010
Internet for 1997 Dell laptop LM ?
You should be able to run a high speed internet PC card, I had Toshiba Tectra that had a built in modem, I bought a high speed card and plugged it into the PC slot and high speed was born.
Jun 25, 2012 | Computers & Internet
Tip
5 Ways to Speed Up PC
Are you fed up with your slow PC? Well you can Speed Up your PC by 3 times. In this post you’ll find some of the most significant ways to speed up your PC. For your convenience, I ’ll split this post into 2 parts.
1. Automatic Ways to Speed Up PC (Using PC Speed Up Softwares)
2. Manual Ways to Speed Up PC
Automatic Ways to Speed Up PC You can use a PC Optimizer Tool to automatically boost the Speed of your PC without the need to worry about the manual ways of doing it. These tools will automatically find and fix upto 99% of your PC errors by optimizing the Windows registry, cleaning up junk files, removing unwanted items from the start up etc. This can speed up your PC and Internet speed by upto 3 times. Here are some of the best PC Optimizer Programs that I recommend.
1. Perfect Optimizer
2. Registry Easy
Using a PC Optimizer is the easiest way to speed up your PC. This is because, most of the performance tweaks such as Registry Cleanup cannot be done manually.
Manual Ways to Speed Up Your PC 1. Free Up Disk Space to increase the speed of your PC
  • Remove temporary Internet files.
  • Empty the Recycle Bin.
  • Remove Windows temporary files.
  • Uninstall Programs that you no longer use.
2. Periodically Perform Hard Disk Defragment. This can Speed Up your PC significantly.
3. Clean Up your Registry (Highly Recommended)
Cleaning Up your Windows Registry is very much necessary to speed up your PC. Unfortunately you cannot do this manually. You have to use a Registry Cleaner to do this. Here is the best registry cleaner on the web.
Registry Easy
A complete review of registry cleaners can be found at Registry Cleaner Comparison
4. Clean Up the browser cache to Speed Up your Internet.
5. Install a good Antispyware software
Spywares can really hurt the performance of your PC. So, install a good anti-spyware to protect your PC from spywares and improve the speed of your PC. I recommend the following Antispywares to protect your PC.
1. Spyware Cease
2. Nodware Anti-Spyware
Which is the Best Way to Speed Up my PC? (Auto or Manual) The best way to speed Up your PC is by using a PC Optimizer such as Perfect Optimizer or Registry Easy. This is because, manual ways can only perform 30-40% of the tweaks to improve the speed of your PC, but the most important aspect of the Speed Up process such as Registry clean Up and other advanced performance tweaks can only be done using a PC Optimizer software. So if you are serious about improving the speed of your PC, then you need to use a PC Optimizer.
AKPC_IDS += "1167,";Popularity: 9% [?]
on Mar 30, 2010 | Computers & Internet
How do i speed up my sony pcg-gr214ep laptop
speed totally depends on ur pc config and the programs installed and used still u can increase the virtual memory on the PC ...disable startup items and stop unwated servies from msconfig....if still needed more speed increase the RAM in ur pc...thanks
Feb 13, 2012 | Computers & Internet
LG P500 how do i connect to internet?
I'm able to connect internet on my pc by using my lg optimus p500 as a modem, but I'm getting only 115 kbps speed while i have 3G card which give me speed of 3.6Mbps on my mobile.
May be this 115 kbps speed is my pc to phone connecting speed. So i can't use my 3G speed
How can I connect my lg p500 modem with 7.2 or 3.6 Mbps to my pc
Jan 29, 2011 | LG Cell Phones
Speed up the PC
You can upgrade your ram and processor to the system's maximum capacity. If you need further assistance, you can call us 24/7 at 800-595-3564.
Jan 18, 2010 | Dell OptiPlex GX260 PC Desktop
Cant show proper processor speed.
download cpuz from the web this will give accurate speed rating sensor on board maybe misreporting correct speed but speed may actually be correct.
Nov 13, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Usb speed problem
I am not sure you can fix it there or different USB types.
  1. USB 1.0 Specified data rates of 1.5 Mbit/s (Low-Speed) and 12 Mbit/s (Full-Speed).
  2. USB 2.0 Added higher maximum speed of 480 Mbit/s (now called Hi-Speed).
Only certian motherboards have the USB 2.0..
That would seem to be the issue..
Sep 14, 2009 | Computers & Internet
High Speed USB Port
This list of cardbus adapters on ebay should do the trick for you. You would have to use a pcmcia device (hopefully you have a slot available).
Mar 01, 2009 | Compaq Armada 110 Notebook
My modem with dial up but not high speed
You might need a new NIC card, thats high speed capable. What kind of hi speed are you trying to use ex.DSL,FiOS,Cable?
May 16, 2008 | Computers & Internet
PC CD-ROM drives
nero 6 have cd/dvd speed, to check ur drive speed,, actually there are a no. of softwares... try google
Feb 22, 2008 | Computers & Internet
IBM Microsoft Windows XP Professional for PC  Logo
60 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
