Question about Kodak EasyShare Z980 Digital Camera
Hello my kodak Z980 shows low battery despite charging the batteries for full m using kodak batteries 2000 and 2400 milliampere
  • 5 Answers
SOURCE: Kodak Z700 not firing up
Guest is right. Clean the contacts, bend the contacts with a small flat head screw driver upwards "GENTLY". This should work. Might have to repeat every couple of months. Forget regular batteries. Use the rechargeable ones. MUST be fully recharged.
Posted on Sep 24, 2008
  • 3 Answers
SOURCE: Charging...Red Light
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Posted on Nov 25, 2008
SOURCE: Kodak Easy Share M873 suddenly not working
What happened is that the camera got turned on in your pocket or somewhere and the lens got jammed trying to open up. The problem is that the outer lens ring is not turning all the way and the camera doesn't fully load.
Solution 1: Put the camera into the charger, press the power button so the green light is flashing, unplug it from the charger. The camera will try to realign its lens. (You might have to do this a few times.)
Solution 2: Manually help turn the outer lens ring clockwise when it turns on.
Posted on Nov 27, 2008
SOURCE: kodak easyshare md41 will not charge battery while
Can the kodak md41 be charged by a laptop through a USB cable?
Posted on Apr 19, 2010
  • 3 Answers
SOURCE: my kodak eastyshare z760 flashes red when on the
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Posted on Jul 31, 2010
Kodak Z980 battery wont last.
I always buy an extra battery or two for my cameras. Sometimes if batteries are over charged [left in the charger for days] or charged too often [charge again after just a few minutes of use each time] they won't hold a charge. Or it could have been a bad battery to begin with. Get a new one and be happier for just a few dollars. Hope that helps, it's what I do.
Oct 16, 2014 | Kodak EasyShare Z980 Digital Camera
Camera is very slow to show image after it is takenover a minute before you can take the next shot also slow to delete images
Hello, Possible low battery power, if battery is several years old they lose their storage capacity, Try another fully charged battery.
Best Regards, Russell
Apr 04, 2012 | Kodak EasyShare DX7590 Digital Camera
I donot know what is wz my battery but it is show 100% but in real it is like 15% plus it is only stay like 15min while it is unplugged
This is a sign that you need a new battery. If you can not get a new battery try calibrating the old one. Here's how:
1. Charge the batter to full. (I know you stated it is like 15% but charge it till it shows full.
2. Unplug the AC adapter and let the battery drain. (If your notebook shut down b/c of low battery, keep powering it on until it will not come on anymore.)
3. Once drained, charge it again to full power and repeat the process at number 2.
4. Finally, charge the battery again. This time it should be recalibrated to hold a full charge close to the factory setting.
Good Luck
C2Solutions
Feb 19, 2011 | HP Compaq nx7300 Notebook
My mobile model is 1100,it show low battery hen it already charged full,what can i do?????
Try to use another battery,if same
Your charging ic has defected,
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 24, 2011 | Nokia 1100
Sagem mobile battery not getting charged to the required level even though the battery is charged the full day, it shows low battery
hello,the battery is weak so i will advice you get a new battery to make you enjoy your phones battery life as supposed.
take care.
Aug 13, 2010 | Sagem Cell Phones
All of a sudden my kodak af 3x optical asperic camera would not turn on. how do I fix this problem?
Hello. This problem is generally due to a low or dead battery. Replace the battery or if rechargeable charge it. IF the problem is still there, take the battery and the camera to any radio shack where they will test the battery and charging system for you. J.
Jul 31, 2010 | Kodak Easyshare V1233 12.1MP Digital...
Kodak C180 for Xmas - The pic of the battery shows
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). The batteries that was in your pack when bought are only test batteries and not rechargeble.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 04, 2010 | Kodak EasyShare C180 Digital Camera
How can I tell what the level of charge is on the battery?
Once you plug the camera to the wall using the charger, the charging ligh will turn on, once it turns off, it means that battery is full.
Thanks.
Sep 27, 2009 | Kodak EASYSHARE M1063 Digital Camera
Dell Inspiron Battery problem
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Oct 29, 2008 | Dell Inspiron 2200 Notebook
Kodak EasyShare Z980 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
