Question about Maytag Neptune MDG5500AW Gas Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
  • Robert Wagner Sep 29, 2011
    i changed thermostats, thermistor, igniter, still no heat
    President:
  • 1,564 Answers
BBoth gas and electric dryers incorporate a thermal cut-out switch. This is so that the dryer drum will not reach temps over the given range. This switch will stop the gas flow and cause a no heat condition. If you own a multimeter check across the contacts of the cut-out in the "Ohms" range. You should get all zeros on the readout.
Posted on Mar 30, 2012
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
Brand new Maytag dryer has been coverted to propane and it keeps breaking (not heating up). The service contractor replaced some parts, tested it and worked fine for 1 day. Today I washed a blanket and...
even though the you might have a new dryer the vent line could be blocked with lint,or there are other parts that could go on a gas dryer,bad thermal fuse,gas coils,ignitor,sensor one of the thermostats,the only way to tell is to get in there with a meter,unplug the dryer remove at least one of the wires on the part you're checking and check the parts for continuity.that's a neptune those are the machines that put maytag out of bussiness a few years ago,i don't think it's new.you can go here and look up the parts i told you to check,if you need anymore help let me know.
Aug 24, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a maytag neptune which is about five years old. It runs fine, but the dryer does not heat up. What should I do orcheck to diagnose problem?
heatman101
Jul 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune gas dryer front loader 9 years old has begun to squeak what is the most likely cause?
Either one of the rollers or the idler pulley is causing the squeak. Most common to go bad in a maytag dryer is the roller on the right, it sits just above the heating element. You need to take the drum out and spin each of the rollers and the idler pulley to determine which one is the problem, and replace it. good luck. Shane
Oct 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer -5 years old squeeks Now it wont start.
There are four small plastic guide wheels that surround the drum in order to keep it aligned. These will wear after a period of time. The wheels have no bearings, they just ride on a metal shaft. You may either try lubricating the rollers or replacing them. Thank you, Dana
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Drum Wont Rotate
did you check to see if the belt was not broke? if not possibly the motor went out.hope this helps
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
117 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
