Question about Keurig B50 Coffee Maker
Part that holds the coffee cups that pierces both top and bottom
  • Anonymous Apr 01, 2014
    plastic side of coffee pod does not pierce, water not passing through coffee pod
    Sniper:
  • 67 Answers
I think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
Posted on Jan 27, 2011
    Champion:
  • 213 Answers
2 Suggested Answers
  • 60 Answers
SOURCE: part that holds the coffee cups that pierces both
yes the K cup holder! Keurig has a patent on that so you will not find it anywhere you will have to call them to get one 1800 cup brew
Posted on Mar 26, 2010
Testimonial: "thank you"
Can I use Cafiza cleaning tablets?
I would not do this. It may damage the internal hose material. I recommend using Keurig's method for cleaning: run 3 cups of white vinegar through it, let it stand 4-3 hours (or longer) then rinse it well by running several tanks of water through it. That will remove all hard water residue within the unit. Also clean out the needles that pierce the cup, top and bottom, with a paper clip, since they often have coffee grounds plugging them.
Oct 06, 2015 | Keurig B70 Coffee Maker
I always have coffee grounds in my coffee when I brew a K-cup. Why is that, and how do I make it stop?
The K-cup must be getting pierced on the top, where it lets the coffee grounds out into the cup during the brewing process. This usually means the K-cup isn't seated properly in the basket.
Apr 09, 2015 | Hamilton Beach 49995 FlexBrew Single Serve...
Keurig 2.0 coffee grounds are everywhere
Ensure the kcups are being pierced by both the bottom and top needles. Be sure to check each kcup is thoroughly sealed before placing it in the brewer. Crushed or dented kcups may not brew properly.
Feb 18, 2015 | Keurig K350 2.0 Brewer
Why does the water splash around the cup rather than stream out ?
Check the removable insert that pierces the K-Cups. It may be dirty from coffee residue and needs to be cleaned. The entire assembly turns and lifts out but be careful as the piercing needle is SHARP. After cleaning, try a new k cup and see if it works ok.
Sep 12, 2014 | Manufacturer KEURIG Brewer a: Mr. Coffee...
Mar 26, 2010 | Keurig B50 Coffee Maker
Coffee grounds in cup w/ Keurig 60
I have the answer because it is happening to me now. Moreso with the Timmothy's brand K cups. I did a little forensics on a good brew, and then on two slow with grounds in the final brewed coffee.
The inner filter is placed in the k cup and it is not glued to the top rim. The bag then just sits on the bottom of the k cup as it is passed with the hot pressurized water.
The good cups are glued to the top rim and there is no problem.
To investigate....remove the foil top carefully after the cup cools. Rinse out the grounds, and the filter bag should still be glued to the rim. if you've got a dribbler and one that passes the grounds into the cup...you will find the filter bag had fallen loose from the rim. Manufacturer defect...You bet!!!
I had 8 from a box of Timmothys 25 count pass grounds. Green mountain coffee may once in a while pass grounds, but very rare and maybe three times in the 4,000 k-cups we've used.
Mar 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Keurig machine releasing coffee grounds on top of K cups
I have the same problem but if you take a paper towel and clean the grounds from the top each time it helps. Cleaning around the little point that pierces the cup. It helps but doesn't completely eliminate the problem.
Jan 04, 2009 | Keurig Elite B40 Coffee Maker
B100 splases coffee everywhere when dispensing
you have lost your upper needel gasket. it look like this an is color si orange. try to found It or call keurig to get new one cfebcf0.jpg
Jan 17, 2008 | Keurig B100 Coffee Maker
Keurig B50 Coffee Maker Logo
378 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
