Question about Toshiba Satellite 5105-S501 Notebook
How to Break BIOS Setup Password - Toshiba Satellite 5105-S501 Notebook
    Novelist:
  • 60 Answers
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Jun 08, 2010
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
I have forgot my BIOS password
The only way to reset the bios password is to reset the bios itself. Depending on the make/model of your computer, there might be a little button on the back of the unit which you push with a paperclip. Turn the computer on and while the BIOS is booting, press the Pause'Break button on your keyboard. That should stop the BIOS boot...Or attempt to get into it so that it waits at the bios password screen, then press the button. It should reset the computer, then when it comes back up (you might need to hit it twice, then turn the power on), it will say something about the clock being wrong, enter the setup to fix it. Go ahead and enter the setup, reset the clock, then (if you need to) reset the password to something you'll remember.
If there's no button, then you'll have to reset the bios using a jumper on the motherboard. The jumper's location varies based on the make/model of your computer. If you respond with said make/model, I should be able to look up how to do it, and I can respond back with the specific instructions.
Tj
Aug 08, 2011 | Computers & Internet
Black screen with a enter pass word
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password..
OR there are other places that will sell you a "Key" for a price.
OR you can provide "Proof of Ownership" to Toshiba, and they will sell you a "Code" to remove the Anti-Tamper, Anti-theft, protection.
Apr 07, 2010 | Toshiba Satellite A135-S2276 Notebook
there is no way to break that password..the only way to remove it is to reset the bios by short the clear bios pins(jumpers)..or remove the bios battery ..this will erase any settings and when you put the battery back will be on optimal factory defaults..(same if you locate the jumpers for clr Bios) but ..for that you have to open the laptop ...its easier for desktops..but for this will be a little much ..but is the only way ...so ..in short be careful and you have to get to the motherboard and remove the battery ...if you do not have an acces point to the jumpers..
Mar 26, 2010 | Toshiba Satellite 5105-S501 Notebook
I forget bios setup password and iwant to know how broken bois hdd password
reset the the bios..disconnect all the input mains power supply..pick open the cmos battery..replace/resit it in again..
this'll hopefully break open bios/cmos password..
to enter in windows..after boot in shell/dos mode n before in windows/gui mode or before the Welcome Screen appears, press Ctrl+Alt+Del..classic logon will open..here in the User Name type: Administrator..press OK or hit Enter..u'll b logged in..
hv professional supervision of ur system admin or vendor....
Nov 05, 2009 | Computers & Internet
Bios password
You can break your BIOS setup password,
For that you have to open your cabinate( be careful at the time of opening, Switch off ur pc first) after this remove battery(CMOS BATTERY looking like your big hand watch battery) from the motherboard and after 30 second attach battery again
and start your PC
goto bios it want ask Passwd
Enjoy
Feb 02, 2009 | EliteGroup 661GX-M Motherboard
What the easiest way to reset the bios setup
just remove the bios battery and place the same there your bios password will be resetted.
and also check this link there are many bios password changing techniques
http://www.tech-faq.com/reset-bios-password.shtml
Feb 01, 2009 | IBM ThinkPad R52 Notebook
How to reset Bios
Good night sir, sir laptop ka bios password kaise tootega.mera laptop compaq ka cq40 moddle ka hai.
Sep 19, 2008 | Acer Aspire 5100 Notebook
Laptops in general don't work that way my friend.
There is a loopback tool for toshibas, however it takes some experience to perform the proceedure.
I always wondered why/how folks install then forget a bios pswd.
Good luck
Nov 28, 2007 | Toshiba Satellite 5105-S501 Notebook
Toshiba Satellite 5105-S501 Notebook Logo
260 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
