Question about LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
My lg washer wm2277hw does not drain water and makes noise
  • LG Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinemy LG washer wm2277hw  does not drain water and - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
2 Suggested Answers
  • 185 Answers
SOURCE: my LG washer wm2277hw does not drain water and
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Posted on Aug 24, 2010
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Sep 23, 2014 | LG WM2487H Front Load Washer
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
I have a tromm washer (model wm2277hw) that sometimes will drain and sometimes not. when it doesn't i get error message OE. all connections seem to be good. when it doesn't drain there is no noise like...
An OE error presents if the washing machine has not successfully drained the water in ten minutes. Follow this link for step by step instructions for correcting the OE error code.
The FixYa Team
Dec 27, 2010 | LG WM-2277HW Front Load Washer
LG washer with OE error
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 27, 2010 | LG WM-2277HW Front Load Washer
My lg WM2277HW is not draining water. It's filling with water and spinning but not draining the water. An oe error is being displayed. I checked the hoses and they seem fine. I checked the filter and there...
Remove and inspect the drain pump. (access is from the bottom of the washer once you remove all screws holding the pump housing in the front)
If no debris found when removing pump or pump impeller is damaged - replace. PArt number 4681EA2001D.
If found debris when removing the pump - reassemble and check again.
Good luck.
Jul 02, 2010 | Washing Machines
Mar 26, 2010 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,163 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
