Question about Boating
I have a 1966 merc110hp as far as i know this motor sat for many years i got her running sounds good but not as fast as i expected i ran acompression test only 80lb on all six i am thinking rings are stuck any suggestions
    Top Expert:
  • 45,446 Answers
Suggest you use plenty of oil in gas and live with what you consider a slower speed . OLD girls(motors) need TLC not full bore pounding
Posted on May 17, 2010
Why stalling out without choke ?
Possible vacuum leak allowing more air into the motor than needed thus the need for the choke to offset the unmetered air. Check for any disconnected/collapsed/broken hoses under the hood
Jul 10, 2015 | Cars & Trucks
Compression
The head on the motor you bought is bad; or the head gasket is leaking; or the rings in the 2 center pistons are bad. 30 lbs is far too low of a compression, and 5 lbs is garbage. They should be closer to 80 or 90 psi and not have more that 5% variance between the cylinders.
The first thing you will have to do is pull the head off and check it. Or you can take it back to the salvage yard you got it from, show them the results from the compression test and either get another motor, or have them refund your money.
Mar 08, 2015 | 2006 Chevrolet Malibu
How do i know when i need new piston rigs for my 07 crf100f
If you ran it out of oil, chances are you're gonna need more than just rings. Good chance you will be rebuilding or replacing the motor.
Nov 28, 2012 | 2007 Honda CRF 100 F
Heating problem: I have a 1996 buick roadmaster wagon 88,000 miles. sat in garage for years so we've put a new starter in it, new thermostat, radiator is great, flushed it both ways, maybe the vent? anyone...
Sounds like you need a plumber. Check the water flow through the heat exchanger, you may find it only needs flushing through or the blades on the water pump are corroded away.
Sep 06, 2017 | 1996 Buick Roadmaster
Model G51MP-48C-110-6; I've downloaded a manual and troubleshooting is usually fun for me, but ;( this time. It ran fine last year, not this fall. Have alternating Green & Red code lights (FAST); I...
Apply power to the inducer motor, or check the voltage to it first.a relay or circuit board will control its operation, if the inducers not running, the pressure switch wont close and no operation .
Nov 01, 2010 | Heating & Cooling
If i press the gas too fast the truck makes a loud sound but wont accelerate will get up to 35 mph then wont any faster the truck was running good before this . it sat for about a year
It sounds like you need to change the fuel filter and change plugs and wires and check and possible change airfilterThe fuel filter would be my first thing to change.
Apr 07, 2010 | 2000 Dodge Ram 1500 Truck
Lack of power in gas pedal
Check fuel pressure and see if its around 30-35 psi while under load if not replace fuel pump, also the gas thats in the tank may be no good if it has sat for so long..
Jan 05, 2010 | 1989 Oldsmobile Cutlass Ciera
66 Mustang- 289 V8- has an intermittent surge and rattling noise
Sounds like crappy gas. The 289 may not like pump no-lead and the rattling sound you are hearing may be pinging / knocking.
Mar 07, 2009 | 1966 Ford Mustang
1999 beetle runs rough
Sounds like ignition coil needs to be changed.
Jan 03, 2009 | 1999 Volkswagen Beetle
Boating Logo
23 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
