Question about Motorola Mobility RAZR V3
Insert SIM message
After charging the other day, i went to turn it on and message came up "insert SIM". i checked the card. i even took out the SIM and wiped it down before i put it back as well as the phone contacts. i have run out of ideas. can you help me please?
  • newychook Apr 06, 2008
    My phone always says insert sim. everything else appears to be working an somehow it managed to detect another bluetooth device but I cannot get into the settings or my contacts list which is saved on my phone. I have tried different sims but to no avail. Is there anyway I can retrieve my contacts list without haim a sim detected in the Phone?
  • Anonymous Dec 07, 2008
    insert sim message
Try your sim card in someone else phone it might be the sim card not the razor
Posted on Apr 05, 2008
Nokia nuron wont read my sim card
When the phone is in offline mode, press the power button and you will get the options in list view. Choose the option General and the phone will become online.
Aug 29, 2012 | Nokia 5230 Cell Phone
My nokia 9300 is dead, i received a phone call and while i was talking i got the low battery message and then it went off, i tried to turn it on again, it is dead, the nokia logo appears for few seconds...
1. let the battery fully discharged without connecting to power supply,
2. remove memory card
3. remove battery
4. remove sim card
5. insert the sim card
6. do not insert the memory card
7. reset the battery
8. connect to power for charging for 24 hours
9. switch on and it will work
inamul@hudaz.com
+91 94350 62943
Jul 13, 2009 | Nokia Cell Phones
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Phone not reading sim card
dont worry there is some prblm in ur sim pls contact ur customer care there is no prblm in ur phone
Oct 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
I get mess..insert SIM card...what's up ? Thanks, Bobby Cantrell blcant@aol.com
that s because there may be some problem in the sim holder or the sim holder is in loose contact ...
if you are good at opening the handset then just open it and remove all and clean the sim holder with some alcoholic solvent and refit that correctly and then get your mobile phone working for the sim cards ...
if you are not good at opening then you can just contact the technician he will make it right but he may take some service charge ...
you will get the "insert sim" message if your sim card has got broken just have a check with the sim card too by inserting that to another cell.. and you may also face this problem if your sim validity is expired ... so just try inserting this sim card to another cell before that ...
any doubts you can reply me
rate my solution ..
have a nice day
Sep 04, 2008 | Motorola Cell Phones
Sim card
change to sim ic your problam is solave
Aug 11, 2008 | Nokia 1600 Cellular Phone
Error messages
1. Is there a SIM card in the phone? Is the SIM card from the same carrier/provider you got the phone from? Was the phone purchased as part of a plan or separately?
2. I see the not charging message a lot with my v551 that I had. I usually adjusted the inserted connector (after insertion) and 85% of the time, the phone recognized the power coming through.
If this fails, then try another power adapter. If after trying a new power adapter does not work, then the pins on the phone has sustained some damage.
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Motorola Mobility V551
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
URGENT: INSERT SIM - UNABLE TO CHARGE
dear for not charging first check ur charger if ok then check and clean charging jeck. even not ok chen the status of solder of jeck if it is unsolder then sold it. even if not ok then check the charging fuse 0 ohams if meter shows continuty then ok other wise replace fuse. for inser sim card check connection from sill card ic(like combice resistor)
Mar 25, 2007 | Motorola Mobility RAZR V3
Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
Oct 30, 2006 | Nokia 3200
Motorola Mobility RAZR V3 Logo
253 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
