Question about Waring WMK300 Professional Belgian Waffle Maker
How to fix waring pro waffle maker- it does not heat up
  • 1 more comment
  • pengel762 May 25, 2010
    H1 TO H2 =120 VAC L TO N = 120 VAC RELAY CLICKS RED LIGHT ON THERE IS A TWO PIN CONNECTOR ON THE PC BOARD, IS THIS TO THE TEMP SENSOR?
  • Ps Daengr
    Ps Daengr Apr 13, 2014
    Most likely the thermal fuse is blown try Amazon.com "Thermal Fuse 240" Its inside a rubbery plastic sleeve, metal-clamped to the bottom grid.
  • Ps Daengr
    Oddly, waring lists the small crimp connectors for the fuse, but not the fuse itself.
    New Friend:
  • 27 Answers
Check out my other FixYa answers for the Waring Pro WMK300.
Posted on May 25, 2010
3 Suggested Answers
  • 5 Answers
SOURCE: Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Posted on Mar 09, 2009
Jerseybob
  • 11 Answers
SOURCE: Waring pro waffle maker
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Posted on Apr 02, 2008
I have a wwm200sa waring pro prof belgian waffle maker that will not get hot. The power light will come on but it will not get hot. Why?
HELP WWM200SA IS WAY TO HOT I HAVE IT DOWN TO 1 1/2 STILL ALMOST BURNED CAN SOMEONE HELP ME THANK YOU VICKY
Aug 02, 2011 | Waring Pro WWM200 Waffle Maker
Waffles sticking to waring pro waffle maker no matter how much spray I apply. Help! thank you
I have had a bad experience with some corn oil spray. The oil (and corn syrup) built up into a crusty and sticky layer. I had to use oven cleaner to strip it back down to the non-stick surface. Now I just use soybean oil with a natural boar's hair pastry brush. (Synthetic will melt!) I heat the waffle maker at the last moment possible. Heat turns oil into varnish. I oil the surface just before the first cup of batter. I like to scrub oil with the brush into all the dry looking areas. If your batter has 1 Tbs (soybean) oil per waffle, that may be all you need for the entire batch. Turn off the heat promptly. I don't wash the oil out of the non-stick surface unless it builds up.
Mar 09, 2010 | Waring WMK300 Professional Belgian Waffle...
Waffle maker won't heat
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. A replacement can be found on Amazon.com at the following URL:
http://www.amazon.com/Thermodisc-Degrees-Celsius-Thermal-Fuse/dp/B000T9VEV6/ref=wl_it_dp_o?ie=UTF8&coliid=I2M3QCVRS1C1IV&colid=2LRN9SBBQ2MW7
Aug 24, 2009 | Waring WMK300 Professional Belgian Waffle...
Will not heat.
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. This appears to be the weak part of the circuit. A replacement can be found here on Amazon.com.
Aug 10, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring Pro Waffle Maker
Had same issue,found a looks like diode on the black wire leading to the heating elements.It is open circuited.Needs replacing.It is not a diode...maybe a voltage circuit protection device.It is crimped into the black wire under the sleeve clamped down near the handle.Going to radio shack to get a idea,replacement.
Jun 02, 2009 | Waring WMK300 Professional Belgian Waffle...
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
Heating element
Feb 25, 2008 | Waring WMK300 Professional Belgian Waffle...
Jan 19, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
1,219 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
