Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
D40X Telephoto Lens Lock
My 18-55 mm Nikon lens for my D40x locked up - does not zoom?  Any suggestion?  Please reply to [email protected]  Thanks!
  • pparkc2020 May 03, 2008
    I have the same camera and lens and I have the same exact problem. It's locked at 55mm and I can't turn it towards 18mm. Just wondered if you found a solution or took it for repairs. If you did, how much did it cost? Thanks,
    Peter
  • Anonymous Mar 14, 2014
    Ho do I turn the child lock offon a Nikon d40x
    Scholar:
  • 105 Answers
This has happened to me on two occasions with two different 18-55 lenses. I would call this behavior "common".
Problem: Inside, there are three "rails" that the twist/turn elements of the lens slide up and down on. On the back of each of these rails is a friction material (glued on). Sometimes this will come loose and start to catch as the lens is zoomed in/out. When the lens locks completely, the sliding mechanisms have become derailed or have gone askew sideways and are being forced in a way that prevents movement (hard to explain without your opening the lens and seeing for yourself).
I have attempted repair of my lens by dismantling it, making the repair, and reassembling. I do NOT recommend this! (many small parts that can break easily). Mine worked for a time but was ruined by my inexperience.
DO NOT FORCE THE LENS or you WILL damage it permanently.You should send it in to a qualified technician for repair. I know this may not be the answer you wanted, but it's not worth trying yourself and ruining unless you plan to buy a new one anyway.
Posted on Apr 24, 2008
SOURCE:
Camera body/lens
Almost all newer Nikon Slr and Dslr cams use the F-mount, So properly yeah
Sep 09, 2015 | Nikon Cameras
My Nikon D40x will not always take a picture when I push the shutter and will not focus whats wrong with it?
I have the same problem and I make this: take out the zoom lens from the body and put it again. The auto-focus comes back. Another my solution: Push autofocus buton to M (manual) and back to A (auto). Then sometimes starts again to work autofocus. But still I know it is not final solution...
Zvonko
Feb 12, 2013 | Nikon D40x Digital Camera
I have been given a 100-300mmF4.5-6.7DL Sigma lens but it will only work in manual focas AF but does work on a friends Nikon is that because my D40X has no AF motor.
That is exactly why the auto-focus (AF) does not work with that lens on this camera. The D40, D40X, D60, D3000, D3100 and D5000 lack an AF motor built into the camera. These cameras will require that the lens have the AF motor to work as expected.
You can review a complete list of lenses (as of 8/2010) that have a built in AF motor here.
Please rate this reply - thanks!
Dec 03, 2010 | Nikon D40x Digital Camera
I want to use fairly telephoto lens in D3 slr nikon camera
You don't say what sort of telephoto you want to buy or how much money you want to spend but basically anything longer than a 50 mm is regarded as telephoto.
A staring point for you maybe the lens listed below: Nikon Telephoto Zoom 70-300mm f/4.5-5.6G IF-ED AF-S VR
It importantly has VR or "Vibration Reduction" on it to reduce camera blur when hand holding telephoto shots. This is just a staring point... You need to work out what you want to photograph Cheers Ian
Mar 17, 2009 | Nikon D40X Digital SLR Camera Digital...
No autofocus
We tried the same lens on another Nikon (D90) and auto focus did not work.
We mounted a new set of lens on the original D40x, and it worked.
Turns out the 2 year Nikon lens (18mm-135mm) was bad. Nikon lens have a 5 year warrantee. The lens will be sent back to Nikon with no service or shipping charge.
Thanks,
K
Dec 08, 2008 | Nikon D40x Digital Camera
A spot appears in same location on every picture
take the lens out and blow air inside the camera and on the inside part of the lens.
Jan 10, 2008 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
166 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
