Question about Toshiba Satellite 1805-S253 Notebook
Satellite 1805-S253 PC Notebook: MY D DRIVE IS READING BUT STOPS. AND SAYS MY FILE ...
My D drive is reading but stops. And says my file is currupte or missing
    Genius:
  • 1,189 Answers
  • Hi, "first," restart the computer, and click on the "Start Button," in the (right pane) select to open the Computer. Check to see if there's a DVD RW Drive (D:) in the "Device: with (Removable Storage) area." If the area is (Blank)? Go to and select All Programs, scroll to find the Media Disk Player. You may need to Setup / Install the player, and "Update the Drivers," when the (install is completed) follow all the instructions. "Remember to always click on the Apply and OK buttons after making the changes, and lastly, restart the computer." "If the problem still exist, try going to the "Device Manager" from the Control Panel, [Roll-back, and or Update Drivers], restart the computer. Next, in a final attempt to fix the problem go back to the (Control Panel), and select from the "Update Options' "Let me Choose... To update the drivers Manually" this will in stall the "original" (Drivers) that came with the computer. "Rating the solution for its helpfulness is appreciated, thanks."
Posted on May 16, 2010
Earlier this week my hard drive went bad. i formatted thedrive and now windows program only gets to about 2/3 rds of the way done on the windows file loading screen and then stops. is the hard drive...
It sounds like the hard drive is going bad. The Installation disks for Windows are capable of checking themselves to see if they're corrupted, or if the CD drive is reading incorrectly.
Since you've already formatted the drive, I would recommend attempting to re-install the operating system again. If this doesn't work I would either take your computer to a certified repair center to have them look at the hard drive, or remove the hard drive and use HDTune, depending on your level of comfort with computers.
Mar 06, 2011 | Toshiba Satellite A135-S4527 Notebook
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
I have a Toshiba Satelite 1805-s253. When I turn it on, it attempts to start but then will immediately shut down with the power indicator flashing orange. I check the power supply and that is working ok.
power supply must b okay but the lead connecting laptop may have gone faulty, try changing it, if this is not the reason then some internal hardware problem
Sep 12, 2010 | Toshiba Satellite 1805-S253 Notebook
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
BIOS password
Not sure if you are up to this but if you remove the bios battery for a minute it will reset you may also be able to search for manual for laptop or you may have one
Jan 23, 2009 | Toshiba Satellite 1805-S253 Notebook
Same toshiba Satellite will not flash problem,,,,,
Hi
Thx for the reply. I think for the meantime we will stict with the BIOS upgrade first. When done then we can sheck out the HDD.
Have you tried the BIOS by Floppy sticking with Toshiba's utility.
The current BIOS v.1.10 is Initial BIOS for Satellite 1800, download ACPI Flash BIOS version 2.10 for Satellite 1800/1805-Sxx4 - http://cdgenp01.csd.toshiba.com/content/support/downloads/1183v21.exe from a Windows PC. Run "1183v21.exe" to extract the files to a folder. Check the readme file for installation info
****Extract from ReadMe File******
A DOS batch file, INSTINFO.BAT is provided in the ZIP archive which will create the BIOS installation diskette.
If all else fails, you can execute the self-extracting diskette image manually. This file is named 1349D21.EXE , and needs a parameter of A: (1349D21 A:) to successfully create the diskette in drive A:
Mike
Mar 24, 2008 | Toshiba Satellite 1805-S204 Notebook
Comes up a grey screen when I turn it on...
had same issue - on 1805-s253 - had to replace the inverter - there was a recall from Toshiba on that part for that series - you find sources for the part via a google of '1805-s253 inverter'
Dec 27, 2007 | Toshiba Satellite M55-S135 Notebook
Can't connect to internet using DSL
Open My computer, then My network places. Then open View network connections. Your connection should say "Local area connection". Right click it and make sure it's set to "Enabled". Then Right click it then select repair.
Nov 08, 2007 | Toshiba Satellite 1805-S253 Notebook
Problem with freezing/starting
Does the machine boot to bios? If so, it could be the harddrive. If it won't even boot to bios, try changing or re-seating the memory. These models are a bit buggy.
Thanks, good luck
Oct 21, 2007 | Toshiba Satellite 1805-S253 Notebook
CD Rom drive
it may be a problem with your autorun, click the link below and install and run the wizard. If still no luck i'm afraid your drive is failing to read the discs and is faulty, assuming you are having the same trouble with other discs. http://www.majorgeeks.com/Windows_XP_Autorun_Repair_Wizard_d4403.html
Sep 06, 2007 | Toshiba Satellite 1805-S274 Notebook
Toshiba Satellite 1805-S253 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
