Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Our Kenmore Oven made a pop sound and a spark came from the top at the back. Now our oven wont work. We tried replacing the fusses with no luck. Any suggestions?
  • 15,935 Answers
It appears your Thermal Fuse has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Popping noise, flames between oven and wall and burning plastic smell from Kenmore gas oven. We had noticed the smell off and on for 2 months, but the oven still worked properly until last night. I...
sounds like the insulation on the cord has been worn through and is shorting out. turn off the breaker pull out the oven and look where the cord goes into the oven and look for black burn marks.
Apr 09, 2017 | Kenmore Ovens
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Evaporative-coil-Parts/Model-867813350/0582/1610510/00007536/00001
Ray
Jan 19, 2011 | Kenmore 94210 / 94211 / 94212 / 94214 /...
While oven was on, heard loud pop. oven no longer
Sounds like your element wire shorted out on back of unit.Try removing back panel and cheak wire on bake element .MAKE SURE YOU UNPLUG OR TURN OFF BREAKER.Hope this helped you out:)
Mar 11, 2010 | Kenmore Kitchen Ranges
Large pop noise tonight while using oven, then problems where buzzer would come on by itself & lock oven. Oven does not work now, nor do the buttons make the usual noise. The stove top burners work...
Sounds like you overloaded a capacitor on the clock assembly. Before you replace the clock, you should check the voltage to your stove to be sure it's a steady 110 to 125 volts. But yes, it sounds like your combo clock brain got zapped.
Mar 07, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Whirlpool oven: oven bulb popped and oven wont work. I already replaced the bulb. Does it have a reset switch? The stove top still works fine. The gas wont come on in the oven so that I could manually...
Sounds like you have an open cicuit in the oven power. The control for the gas uses the impedance of the hot surface igniter. Check for a circuit breaker. The wiring diagram should be inside the control panel cover.
Jul 07, 2009 | Kitchen Ranges
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
Kenmore oven
Is this an electronic control oven...touch pads to set temp? May have a bad ERC. Electronic Range Control. Also check oven sensor. This is steel rod in oven in back wall near top on left or right. Check ohms from the rear where it connects to harness. Disconnect at harness and measure resistance of sensor. Most are around 1.1k.
Oct 07, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
GAS RANGE OVEN CAN'T SEE THE MODEL ON THIS SITE JPBC????
Sounds like the sparker in the oven isn't correctly installed, if you hear gas try and light it with a lighter, (WATCH OUT FOR YOUR FACE)
Aug 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
138 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
