Compaq presario v5000 wont turn on
No power tried removing battery and just plugging it in. No luck.
  • 4 Answers
If you do not see any light on the power adapter even after checking with a good known wall socket.The it is probably the dapter that has gone bad , if you are still in warrenty then ask the HP for a new adapter or otherwise buy a new one
However you can also try to do a flee power that some times helps a lot. To do this remove the battery and disconnect the power adapter and then press and hold on to the power button of the laptop ( this is the button that you press in order to switch on the laptop ) for 20 to 30 seconds , then reconnect the adapter and try switching on the laptop.
Let me know if thi8s helps and I will be glad to assist you further.
Posted on May 17, 2010
first of all you take a tester and then pullout the wire in S.M.P.S and turn on the U.P.S then put tester on the pin, if the tester glows then the power is coming to SMPS but then the problem could be in SMPS or your motherboard
if the tester does not glows then the problem could be in your UPS surely
Mar 26, 2010 | Compaq Computers & Internet
My compaq presario v5000 does not power on?
Please try to plug the power cord into the source and used DC power source. Let the laptop charge for 5 - 10 minutes then after the given time please turn on the laptop. If it does not work extend the time from5 -10 to 15 - 30 minutes then repeat the stpes again. If it does not turn on then please try to check if the battery is charging. Then if all the procedure you have already perform and still no positive result then i advice you to please find a computer technician in your please and let that person fix the problem for you.
Thanks
Aug 04, 2009 | Toshiba Satellite M40-S417TD Notebook
Hello GOD BLESS YOU all. my latop is compaq presario V5000
You can download latest drivers for your model here
Apr 09, 2009 | HP Compaq Presario V5000T Notebook
Laptop wont turn up
Check the adapter.If it is good then its the DC jack.The only other thing it could be is the motherboard.
Oct 27, 2008 | HP Compaq Presario V5000T Notebook
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Needing to fix a compaq presario v5000
The screens on these computers can and will go dead after a while, afterall its an old computer..try an external desktop monitor by plugging it in the back(blue port)
If you want a new screen go here
Good luck..and if you have any questions about your armada just ask.. I have 5 of them.
Oct 01, 2008 | Compaq (241995001) Plug-In Module (Laptop)...
V5000 problems
what you need 2 do is either take the whole laptop back 2 where you brought it or even the battery cause you have a faulty battery.
most laptop batterys last for at least 5-10 years and after that no matter how much you charge them up they alwayz seem to be flat.
so my suggestion is get a new battery or take it back to the place that you brought it from and than get it replaced for free as long as you have your recept.
Jul 06, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
Compaq v5000 wont turn on
Shorted MOSFET in the secondary most likely.. These are trash..
Nov 14, 2007 | Compaq Presario V5120NR Notebook
My compaq presario v5000 shut down and wont restart
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
David Payne
David Payne
