Question about Toshiba e-Studio163 Copier
Toshiba 160 error code
Toshiba e-studio 160, c44 error code.. how can i reset this code.. pls help me..
  • Anonymous Apr 19, 2008
    My copier show a error "Registration Broken" plz solve my problem
  • 43 Answers
C44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
  • Anonymous May 08, 2008
    broken registration error = memory error
    try turning off then hold * 1 & 3 (hold down all three keys) and turn on
    wait till it says pleas wait then you can let go
Many thanks falz1982, your comments and the information given were very helpful.
Nasser Alaoui
Posted on Feb 13, 2009
    New Friend:
Call for services
Posted on Jun 24, 2012
  • Toshiba Expert
  • 414 Answers
Press ( 0 + 8 ) then press 400 then press enter/print set 0 press intruppt
hope solve it
Posted on Aug 17, 2012
  • WASEEM SHAHZAD
    WASEEM SHAHZAD Sep 03, 2013
    i entered these codes but faults is still same
2 Suggested Answers
SOURCE:
  • 727 Answers
SOURCE: toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Posted on Mar 09, 2009
Toshiba e studio 18 error c43 how to reset
Dear sir i have to problem in Toshiba estudio 18 error c44
and fuser unit check ok but please tell as error reset
Jan 05, 2014 | Office Equipment & Supplies
Error c44 studio
codes c43, c44, c45
problem with the fuser
thermistor review
thermal fuse
check connectors
Dec 05, 2013 | Toshiba e-Studio 35 Copier
Error codes and their meaning for Toshiba e-studio 181 copier
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Apr 27, 2012 | Toshiba e-Studio 232 Black and White...
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
I have a Toshiba studio 45 with error code c44, what can I do ?
You should apply to service Toshiba.
The Possible faults in lamp of the heating, thermistor, contact of the elements of fuzer or in signal of the controller of the direct current.
C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem
Oct 07, 2009 | Office Equipment & Supplies
Can we refill toshiba e-studio 207 Tonar Cartige ( Cartige No.T-1640D
sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
Sep 03, 2009 | Toshiba e-Studio 205 Copier
My Toshiba e studio 167 is showing a c44 error code. What should I do?
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Jun 30, 2009 | Toshiba E-Studio167 Copier
I have a Toshiba estudio 160 which has come up with the message "call for service" with no other error code.I pres the c key and the 8 key at the same time and the numeric code was c44.Please help me
Error Code C44 has to do with the fuser section of the copier - probably not warming up fast enough and got tripped. There is a reset function for this but it's done by the technicians, not users. Once reset it should be OK but you need to make sure that this copier has in-line surge protection as spike in the line can cause simialr problems in most copiers.
Mar 24, 2009 | Toshiba E-Studio 160 All-In-One Laser...
Mar 09, 2009 | Toshiba E-Studio167 Copier
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toshiba e-Studio163 Copier Logo
2,720 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
