Question about Crown CE1000 2-Channel Amplifier
Fan running I just bought a crown ce1000 -should the fan come on later when the amp heats up?
  • Crown Master
  • 5,603 Answers
Yes, many of the pro sound amps throttle the fan based on an internal temperature sensing device.
Posted on May 16, 2010
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: fan running
This is a very sophisticated amp and it will turn the fan on at various speeds when it feels the need for it. Of course, if it's running REALLY hot, going into thermal protection and/or posting a fault you might take a look at it to see if it CAN turn (no obstructions).
Posted on Mar 26, 2010
Testimonial: "Thanks for the help that explains a lot."
My crown ce1000 fan stop working dont no why
Check for broken wires, Or if that is not the problem fan could be burnt out. Also check if there is a separate fuse for the fan.
Sep 03, 2014 | Audio Players & Recorders
Why fan stop working
If the fan is not working, it could be the fan itself, or it could be missing the voltage to drive it. I wouldn't use the amp with this condition, as you may cause output failure. If you need more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 03, 2014 | Crown CE1000 2-Channel Amplifier
Is the fan on a Crown CE1000 to run all the time or only when the amp is under a load and requires cooling? It seems that the fans try to run while on. Almost, as if, the cooling fan is polarized.
The fan speed is dependent on the surrounding temperature.
It may be the temperature is just beneath the fan stalling speed
You can test this by heating up the amp a bit.
Dec 23, 2010 | Crown CE2000 2-Channel Amplifier
The fan on my CE1000 does not come on when the amp is powered up. The amp seems to be playing normally, but I am afraid I may over heat the amp if the fan is not working. Is this normal?
The Thermal Senser on the Heat sink may be Defective. Heat the Thermal senser and see if Fan Turns on. It is a device with 2 screws holding it to the heat sink
Oct 07, 2010 | Crown CE1000 2-Channel Amplifier
Fan running
Mar 26, 2010 | Crown CE1000 2-Channel Amplifier
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Crown CE1000
Hi waveybnc
The fan has failed, or is clagged up with dust. Remove it and clean it first. But best to just replace it. They are not that special and there is not alot that stops them from working. You can get a replacement device for the amp from Crown direct, or once you know its dimensions and power requirements, from here.
Thanks for using FixYa. Please rate my advice to you here as FixYa if it helps you.
regards
robotek
May 25, 2008 | Crown CE1000 2-Channel Amplifier
Crown CE1000
Cuold be the final power amp ic. Might be imput transistors to that channel. Its possible to have a cold solder joint on pcb.
Look close at board with good light and a mag. glass to see if any foggy looking joints and heat up with soldering iron then dab with fresh solder.
Good Luck
BigRED
Oct 20, 2007 | Crown CE1000 2-Channel Amplifier
Crown CE1000 2-Channel Amplifier Logo
192 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
