Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
How to format the LaCie 500GB d2 Quadra for Windows XP??
I am having problems trying to format this drive (LaCie 500GB d2 Quadra) for my PC. Can someone HELP me????
  • 242 Answers
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Posted on Mar 31, 2008
I have the same problem, but in my case it appears a s "not assigned" so when I can do the right click on it it just let me see its properties, but I can not format it.
Do you have another solution?????
Thanks
Posted on Jul 24, 2008
I am trying to set up the LaCie d2 quadra. I follow the steps in the manual but nothing is loading to My Computer.
you will need to go in Disk Management and format the drive first then it will be available in My Computer.
Regards,
Dec 30, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
How can I format an external lacie drive to mount on both a PC and a MAC without partitioning
You can not use the drive on both systems. It has to be formatted for one or the other. To transfer your files, I would either backup your files to CD's/DVD's or try to network your Mac and PC, then just dump your files to a share folder of some sort.
Jan 09, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows...
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Sep 14, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I need to be able to use this hard drive on my pc
DataViz makes a product called MacDrive7 that can be installed on a Windows PC that will enable it to use pretty much any kind of device that has been formatted for a Mac. The other option would be to format the drive for a PC since a Mac can utilize PC formatted disks, but you will lose options like forks, etc that are Mac-specific.
Jun 01, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
May 19, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB was formatted for MAC and given for use on PC. It does not show up anywhere when plugged in, blue light on. pc says device detected, but does not recognize and it does not show up in control...
You will need to format the device for Windows use. If you can see the device in My Computer, right click it and select format. if you can't see it in My Computer, you will need to use a boot tool such as Gparted: http://gparted.sourceforge.net/download.php
Download the .iso file and burn it as an image to a cd, then boot from the CD at startup. It should detect the 500 Gb drive and allow you to format it to NTFS. Then Windows will recognize it.
Mar 09, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
2,540 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
