Question about GE 36 in. JGP628 Gas Cooktop
We havent purchaced this cooktop yet but are putting in electrical outlets do we need a 110 outlet for this model?
    Guru:
  • 351 Answers
It would be a good idea to plan for an outlet for the cooktop. most do use 120 volts for the spark device. Locate it behind or below the cooktop so it will not be confused with your countertop outlets.
Please Vote !!
Posted on May 16, 2010
How do I access the cable connection point of my gas cooktop cir60xs3. The lead is too short to reach the power outlet. Hence, I need to replace this with a longer lead.
buy an appliance extension cord and use that .or have an electrician come tp put an outlet close to your appliance .
Nov 08, 2016 | Cooktops
My oven wont work, the display wont appear
check the power to your oven and make sure that you have 110 volt in your outlet using a voltmeter.
Oct 19, 2014 | Whirlpool Gold GY399LXU 30 in. Self...
Need a template for Whirlpool GJC3055RS Stainless Cooktop.
Go to the supplier/outlet you purchased it from....they will have one from their demo room.
Jul 21, 2010 | Whirlpool GJC3055RS Stainless Steel...
None of the four burners will ignite when the gas is turned on. The electric igniters don't spark. The gas comes out and can be ignited with a separate butane lighter. I believe the electric power is on to...
Check that electric power closely. A boil over and attempted re-start or water (or other liquid) leaked / spilled into an igniter switch can trip your GFI outlet. Sometimes the outlet the cooktop is plugged into is fed from a GFI recepticle further " up stream " so you may have to look around to find a GFI which has tripped.
Feb 08, 2010 | Cooktops
Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
What electric voltage plug do I use for KitchenAid 32" cooktop
I would use the 220volt 60amp available at any hardware store. Just make sure you check the wall outlet you are going to use. The Dryer and Range are not the same.
Nov 03, 2008 | KitchenAid 32 in. KECC508 Electric Cooktop
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Ignition keeps clicking
the spark modual is bad and needs to be replaced
Nov 25, 2007 | Thermador 37 in. CEF365CS Electric Cooktop
GE 36 in. JGP628 Gas Cooktop Logo
43 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
