Question about iRiver H10 MP3 Player
Iriver Troubles My Iriver H10 MP3 player has a "DB Error" at the playlist menu... What should I do???
  • 8,596 Answers
Delete the playlist and try to re-add using windows Media Player - make sure EVERY song in the playlist is in the right format
Posted on May 30, 2008
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
Printing playlists..??
I have no idea, I dont deal much with software issue/help
Dec 19, 2007 | iRiver H10 MP3 Player
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
Windows media player vs. h10 20gb
Fimrware upgrade might actually result in this problem - check the iRiver help forums - i believe I saw a horde of people with this issue
Oct 27, 2007 | iRiver H10 MP3 Player
IRiver H10 20 GB
Hi Vera I am using windows2000 OS, can not yet justify a faster Pc to run XP .. following is what I use to load and manage my MP3 audio files on my H10 20GB >using an alternative to WMP 10, I use 'EasyH10' .. prepares an H10 player without iriver plus or Windows Media Player 10 based on music and playlist files transferred manually using windows Explorer easyh10-15.exe Info re Easy_H10 URL http://www.misticriver.net/wiki/index.php/Easy_H10 URL http://sourceforge.net/project/showfiles.php?group_id=138812&package_id=152796 download 'easyh10-1.5_win32gui.zip' - connect USB cable between Pc and H10 - place H10 in 'Lock' position - use a tool ( refashioned paper clip ) to press the reset button - start H10 in USB Mass Storage Device Mode... Hold down 'O' button, continue holding 'O' button while you press the 'On / Off ' button until screen displays USB connection, after emergency display - In Windows Explorer locate the ' removable drive' - Transfer your music files with tag information to 'Music' directory on H10 - Run EasyH10 - for Media database construction to display songs in MUSIC mode. - Playlist conversion, a necessary process for your playlist files to become compatible (recognizable) with an H10 player. - EasyH10 also imports/exports tuner presets from/to a text file. Prh
Mar 18, 2007 | iRiver H10 MP3 Player
IRiver H10 - Cannot update playlists
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Feb 20, 2007 | iRiver H10 MP3 Player
Sorting music, rename & creat playlists problams
Provide more info 1/ what windows OS R U Using/2 H10 requires Windows Media Player ver 10 3/ If you do not have XP to run WMP10 then connect H10 in UMS mode, transfer audio files and playlists using windows explorer 4/then use EasyH10 to update the database on H10
Dec 25, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
186 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
