Question about Toshiba Satellite M45-S265 Notebook
Toshiba windows xp problem
I recently erased everything on my hardrive and now when reinstalling xp it gets to the boot screen and the license agreement when i accept it asks me to insert a valid windows xp disc i do and it says it cant read the disc or cant recognize it whats going on?
  • 813 Answers
Hi friend
ur windows xp cd is corrpat to make new copy of ur windows xp cd & try to install if not insatlls bye the windows xp cd
or try to install onther from the onther cd
if problem occers then u have to repartioin of ur hard drive & try to install windows xp
thnx using fixya
Posted on Mar 31, 2008
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
Change boot order for toshiba g20
You have to format your hard drive using a third party disc to erase everything on your hard drive
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Hope this helps.
Dec 12, 2012 | Toshiba Computers & Internet
Can i erase the hardrive of my toshbia satullite 1555cds and run windows xp
Why not ther is no problem just keep in mind the capacity should be 60 GB or above
just buy a windows xp original and put in the laptops cd drive restar the system boot from cd or dvd press enter and thats it you will be asked for formatting the hard drive.
Apr 18, 2010 | Toshiba 10GB NOTEBOOK HARD DRIVE KIT...
Black Screen on Dell Dimension 3100 on boot up. Running Windows XP Home Edition. This happen before you get to the Windows login screen.
If you have a black screen it means the system cannot boot into your master boot record, you should reinstall the system using a bootable Windows XP CD, and perform a repair,( not the Repair Console).
When youre in the Windows XP Wizard screen, press enter , accept the license agreement, and then it will check for existing windows xp partitions, press R to repair the existing Windows XP installation, and wait til it gets your system restored.
Jan 10, 2010 | Computers & Internet
How do you reinstall Windows XP on an Toshiba Satellite A60 PC Notebook?
1. boot your PC or laptop from the Windows XP CD (To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer).
2. You will see "Press any key to boot from CD" displayed on the screen, at this point press any key to start the computer from the Windows XP CD.
3. You will see the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4. Read and agree to the Microsoft Software License Terms, and then press F8.
5. Follow the instructions to select and format the c: partition where you want to reinstall Windows XP.
6. Follow the remander of the instructions on the screen to complete Windows XP Setup
7. Reinstall any drivers which are required.
8. Reinstall any software programs which you need.
9. copy your data back to the drive.
Jan 07, 2010 | Toshiba Satellite A60 Notebook
Can't boot from USB (No CD Drive) for fresh install
Tricky one, ive you have a external usb cdrom drive , maybe, or if you can take hardrive out and set it up on another laptop install your xp and also place copy of all drivers required onto it, then put back into the toshiba., dont know what else could help you here. hope this helps in some way.
Dec 05, 2009 | Toshiba Portege 7100 Notebook
Dell Latitude won't boot up and reinstalling Windows XP is taking forever
well it could be a bad sector on the hardrive .. couple of questions did you reformat the drive you are installing it in? Did it give you that option on your reinstall?
Sep 21, 2008 | Dell Latitude D600 Notebook
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
BIG BOOT PROBLEM!!!!
You should have erased the system root directory,( the Windows XP installed drive). the boot sector still has the winxp boot information, but does not finds any file on the drive, were they are supposed to be.
You have to Install a fresh copy of winxp, with the winxp boot cd.
Jan 09, 2008 | Compaq Presario 5000 PC Desktop
No video on boot up!!
have you tried to uninstall the vedio driver and reinstall it then let me know.go to my computer icon right click it > go to properties >hardware tab > device manager and check if there is any yellow mark showing.kindly do this in starting your computer in safe mode.
Oct 09, 2007 | Gateway 500XL PC Desktop
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
