Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
I have the Makita DC18ra s charger for 110V. by mistake i insert it to 220and burn the fuse and a components as described on the borad VDR1 01 Do someone knew what is this components thank alon
Yes you can fix it i have done 2 charges but white you are in there if you chance the large round capacitor to a 450v one you then can use the charger in 220 v you will have to increase the size of the voltage resistant diode to 240v (the vrd101 part in the charger) or by pass it with a straight bridge then the charger should work in 220v because the rest of the charger is exactly the same the parts will be around $10 ibought the parts from farnell
Posted on Jul 14, 2010
  • 2 more comments
  • petricam2006 Apr 05, 2011
    Where do you live man. I have a charger with the same problem. Can you help me
  • Emil Rutiku Aug 14, 2011
    Hello I have this DC18RA S and want to change to 220V.
    Can you please send me how to do that.
Is there anyways i can modify my charger to run off of both 110V and 240V
Posted on Apr 21, 2012
    Scholar:
  • 130 Answers
How you place 220 volts on it is a issue in itself. You can go onto ebay and get a new one for less than $25. Far less that what you would pay to ship the components that burnt out.
Posted on May 16, 2010
110v been pluged into 240v so does not work.solutions
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 11, 2014 | Makita DC18RA Rapid Battery Charger For...
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
My charger is accidentaly connect into 220v and this is burn. im here in philippine. its this to repair and i use again...
Is this a 110Volt version that you plugged into 220v?
There is a ceramic Fuse inside the unit that might be blown. It is the first thing on the circuit board near the power cord connection.
Open the unit up and post a photo of any burned components ?
Jul 10, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Where can I get a schematic diagram of Makita DC18RA Charger?
my battery charger ic broken for a.c power flechuvation so iam not seeing that i.c number so i will ask you model DC18RA
Feb 14, 2011 | Makita DC18RA Rapid Battery Charger For...
MAKITACHARGER 220v to 110v problem after using of right converter
hi all,
I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
Jan 07, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita DC18RA charger conversion
You can't use the same capacity as it gives you a very
large and expansive capacitor.
I used the max. diameter of 30mm that could go into the PCB of the model I have and it is 470uF 400V
You'll need to replace another capacitor, see my mod page !
This works !
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
all the components details are in it
Jan 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
DC18RA from 110v to 220v
The varistor you have to change is the one that runs parallel on the current after the fuse, in my case it was easy to find as it was the one with the plastic hood on it.
I'm going to update the webpage with some new pictures that I hope would hetp to clarify it.
Nov 16, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Jun 27, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18v 120volt american charger to be used in australia
Don't go buying more stuff when you can fix the problem yourself without buying any converter. The modification required to do it is very easy and most people wont have any problem following it.
You can go to this webpage where a detailed walkthrough is given (with pictures):
http://www.byggebolig.no/index.php?topic=5572.0
Some of the post are in norwegian but the walkthrough is in english.
Good luck and happy moding :)
P.S.
For those of you that have "blowed up" a makita charger 110v on a 220v, don't throw it away!
If you are lucky you have only blowed up the fuse and the varistor, which are easy to replace, and if you follow up the walkthrough you might even go all the way a mod the charger to 220v.
I know, I have already manage to "save" a blowed up charger.
May 16, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
3,326 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
