I think what you need to do is reinstall your sound cards driver. or reinstall windows system.sometime reinstall system is more easyer than install soundcard driver.
Try to uninstall and reinstall the driver back maybe the file just got corrupted, how?
Here' what you need to do: - Go to device manager - if your sound card driver is not working then you will see an icon with a yellow exclamation mark this is your sound driver. - remove it then reinstalled it back by just refreshing the device manager - this will automatically install the driver back and this should resolved the problem
If not,then you can try to restore your computer back to previous date where your sound driver works, just think of that date and use System Restore
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustmentsthere click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar hope this helps
You will need to reinstall the sound drivers.
Go Here
http://www.msi.com/index.php?func=downloadindex
Enter the model of your board and download the drivers for your operating system, then install them..
i think your sound drivers are corrupt...just reinstall the sound driver that are come with your motherboard driver cd..then play the sound after reinstall sound driver...
go to start, configuration, hardware and see if there is a yellow ! next to your sound device. Ifso, reinstall the drivers. If there is no sound device at all also reinstall the drivers and than restart. Before doing this check if your sound is not muted or set extremely low.
i think you need to reinstall the sound driver and check whether it appears in the CONTROL PANEL->SOUND AND AUDIO DEVICES. When you click the sound and audio device, your sound driver name should appear.If problem persists then it might be hardware problem.
