Question about Gigabyte GA-8I848P-G Motherboard
GA-8I848P is dead
The motherboad wont startup when i push the power button nothing! so i changed the power supply still nothing
any ideas would be apreciated
  • arked Mar 31, 2008
    did this happen all of a sudden. yes
    no nothing was changed
    when you turn on the power does the power led lits? the system/cpu fan rotate?
    no no leds light up the fan does not rotate
  • witts_1 May 09, 2009
    I'm having the same problems. I bought this pc fom someone and I seen it working. The person wanted to keep hard drive and memory. the I replaced memory with the same that was removed and installed hard drive with IDE cable. When I push the power button the fans try to move then a light comes on beside the memory. Any ideas.
    Problem Solver:
  • 6 Answers
You can check the bios chip it is may be deamged
Posted on May 28, 2009
  • 4 Answers
Verify that all components are connected correctly. Make sure that you have enough wattage to power your machine. Also make sure that the power switch is connected to the correct jumper.
Posted on Jul 03, 2008
Did this happen all of a suddent? it was normal or you tried something in your board and it did not work later?
when you turn on the power does the power led lits? the system/cpu fan rotates?
Posted on Mar 31, 2008
I got Gigabyte GA-81915P PRO Motherboard. Swich on the power there was a bang - power supply caps were blown. Got new power supply when I switch it on it immediately switches off - nothing on the monitor....
Have you tried checking if you motherboard had been damaged when your power supply exploded?
Cause theres a big chance that your motherboard will be damaged, cause explosion of power supply will trigger excessive voltage to your motherboard.
So if your motherboard is damaged,there will be no chance for your computer to turn on even if you change your Video and Memory Card.
Jul 04, 2011 | Gigabyte GA-8I945P-G Motherboard
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
I have a PC motherboard model is GA-8I848P ... have problems is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Dear, If you have checked power supply, memory and cmos then there is problem in your motherboard its not giving display. check your motherboard warranty and replace it.
Jun 18, 2011 | Gigabyte GA-8I848P-G Motherboard
GA-8I848P(-L) Motherboard won't boot. Was an intermittant problem as it would occasionally not boot but would be ok after a reseat of memory or a period of being off. Now it no longer boots. Have changed...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 19, 2011 | Gigabyte GA-8I848P-G Motherboard
My Lenovo 3000 J Series switches itself off at startup before the opening of Windows xp. Any ideas? This message is from another pc.
the problem of power off after startup can be caused by:
  1. a Faulty ATX power supply (the power good signal was not prperly generated to the motherboad)
  2. Cpu fan problem, the CPU temperature is abnormal
  3. faulty motherboard
to solve this problem, first change your ATX power supply unit with the same power rate. then clean the radiator and the fan. if the problem still not solved change your motherboad.
Dec 13, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
I'm the one with the GA-8I848P-G but, i had replaced my keyboard, and i had reinstalled the windows
Sorry..But You may have to be more clearly on that deal, Please explain with detail you situation tanks ...
Oct 18, 2010 | Gigabyte GA-8I848P-G Motherboard
Tv wont come on at all..push the power button.. nothing, use the remote..nothing, not even a flicker...please assist
hi..this is probably an issue with the power supply
of the tv.check the power supply.
thank u..
kindly rate my response..
May 09, 2009 | Protron PLTV-37 37 in. LCD Television
GIGABYTE GA-81K1100 wont boot
In short, new motherboard time. Something small & irreplaceable is dead.
Feb 18, 2009 | Gigabyte GA-8IK1100 Motherboard
Computer wont Boot up normaly
first romove the power cable. then remove the ram, then remove the agp or pci express if you have. Then adds this thing together. add power cable.
Start the computer.
Jan 21, 2009 | Gigabyte GA-8I848P-G Motherboard
Gigabyte GA-8I848P-G Motherboard Logo
249 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
