Question about Dishwashers
Kitchenaid built in dish washer Model
Kitchenaid built in dish washer Model #KUDMo1TJBLo issues. Control panel buttons not responding. Rinse Only and Canceleset button lights flashing. It won't let me choose a cycle or start on rinse only. I tried turning off the breaker and then turned it back on but the same two buttons are blinking.
reg501
  • 413 Answers
SOURCE: My KitchenAid dishwasher model KUDM01TJBS0
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Posted on May 29, 2008
bestdarngood
  • 3037 Answers
SOURCE: RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
The keypad interface is bad, you would need to replace that and then it should work great. Let me know if you run into any trouble or have further questions and I would be glad to help.
good luck
Posted on Jun 02, 2008
  • 93 Answers
SOURCE: KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
Posted on Jan 21, 2009
SOURCE: kitchenaid 577-0 Rinse aid cap fell onto the
Buy a new one.  I had a similar problem.  Website link is below from where i purchased on for around $26+shipping.  I later found one for about $22.  Couldn't locate that website for you, but here you go:
www.apwagner.com/index.php?main_page=product_info&cPath=866&products_id=116675
Posted on May 28, 2009
  • 15 Answers
SOURCE: Food particles are being thrown back onto dishes
i would suggest you dont put the food particles in the dishwasher in the first place,it sounds like you need to clean your filters out as it is a funny fault,
Posted on Apr 12, 2010
I want to know what was the exact maker/model, part# of your unit
Thanks
Jun 01, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Kitchenaid Dish Waher KUDI01ILBS1 won't run from control panel
Sounds like the control is bad. Turn off the power, remove the two screws at the bottom that secure the kick panel. Remove the kick panel and look under the machine for a folder up tech sheet. This will tell you how to get the machine into diagnostic mode. Follow the instructions exactly and it will help confirm whether it is the control.
Jan 15, 2010 | KitchenAid Washing Machines
KitchenAid dish washer: Control Panel Problem
Circuit board/ Electronic control assembly needs to be replaced.
Jul 24, 2009 | Dishwashers
Maytag dishwasher cannot choose cycle on light panel
hello hmm ok so no lights it sounds like your control panel after unplugging your dish washer check the panel for loose wires the panel is the part behind were your buttons are located will have to remove your back cover to access this if that's all good then try your power cord again make sure its not got any loose wires were it attaches into the dish washer have a nice day and good luck let me know if you find anything.
Mar 19, 2009 | Maytag MDB9600A Jetclean II Built-in...
Food on dishes
Dish washers are not good at removing food debris.  They filter the water somewhat but in the main, they recirculate whatever was on the plates when you put them in plus the detergent.  The rinse takes all grease and solubles away.  Scrape your dishes of as much as you can before putting them in.  Use a good detergent in the amount specified.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid Dishwasher
Nick,
It sounds like you have tried all the normal things for this. It is possible that you have a stuck key on the panel. Try pressing all the buttons several times to see if they may be stuck. It may just pop it loose. If that does not work you may need to try kicking the breaker off overnight. If that does not work you may need the electronic control. Lots of luck to you. Mike
May 07, 2008 | KitchenAid 24 in. KUDP01DL Built-in...
Setting cycles and turning dishwasher on
Frenda Most likely the problem with your dish washer is shorted one or more pads on the key panel. To fix it the key panel has to be replaced. If you'll provide the complete model number and color for the control panel for your dish washer, I can help you to find the best deal on this part. Gendos
Jan 17, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
