Question about Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Actually, it's an MW24FP3 VCR unresponsive
Won't play rewind or eject loaded VCR cassette.
"Display" button shows it in stop mode.
"Menu" button skips over DVD icon.
"Program" button won't allow altering or deletion of the single timed recording data.
Record light is on.
  • Anonymous Mar 13, 2014
    tape loaded into vcr but screen says cannot record?Tried different cassettes , no luck?
After Checking Toshiba FAQ, it turns out that the record button must be turned off to do anything, including playback.
Posted on Apr 01, 2008
Cassette is stuck. Cannot eject
Sounds like the tape is dragging and the spindle wont release it because of the torque on it. Can you rewind or fast forward to see if it releases?
Sep 09, 2012 | Samsung DVD-V4600 DVD Player/VCR
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
GR-DF420E my cassette is stuck in the camera and display shows that its gone in safe mode. HELP HELP HELP It doesnt do anything, tried new battery aswell
Hi,, try to put the camera in vcr mode and press rewind button and fast foward alternately until the tape start to move then press eject few time
if its not a big mechanism problem you may be able to ejected if not that will have to be made manually
by removing the cover and look where the tape is hook in the mechanism ;i sugest to you to call a
good technician
hope that will help you.
Apr 08, 2010 | JVC GR-X5 Mini DV Digital Camcorder
Tape would not come out.
Not sure on the removal, but if you replace the mode switch the machine might come back to life.
Jul 31, 2009 | Panasonic PV-7400 VHS VCR
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Toshiba MW24FP1 24 in. TV/VCR/DVD Combo Logo
115 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
