Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked washer/dryer - washer problem
I have a Kenmore 417.90862990 stacked washer/dryer. When the wash cycle is done and the tub is supposed to empty before it spins, it does not empty completely. The washer enters the spin cycle with water still in the tub, which is resulting in leaking in the next cycle. I checked the air tube and it appears to be fine. The pump works too. I have to hold the timer switch in a certain position at the end of the wash cycle so that the tub will drain completely. This also happens after the rinse cycle before the final spin cycle. Any solution to this problem? Thanks.
  • 2 more comments
  • rmsb1023 Apr 04, 2008
    I ordered a timer, put it in and it didn't fix my problem. I then figured it was my pump. Took the pump off, opened it up and found a necklace with lots of lint clogging up the pump. Cleaned the pump. Problem solved.
  • kevinpotschk Jan 12, 2009
    my dryer will not completely dry. I have checked what i thought was everything but i guess not, cleaned around drum, all duct work, fan, heating element is very hot . timer works. Any help would greatly help.
  • Anonymous Mar 21, 2014
    Washer will not spin after the rinse cycle.
  • Anonymous Mar 28, 2014
    whirlpool washer won't spin or empty at end of cycle
WHEN I DRY MY CLOTHES THE DRYER S LEAVING BURNT MARKS AND HOLES IN MY CLOTHES. WHAT COULD E CAUSING THIS TO HAPPEN?
Posted on Sep 06, 2010
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Where do you find the timer?
Posted on Nov 13, 2008
  • 185 Answers
Check the timer
Posted on Mar 31, 2008
My Kenmore Washer Dryer Combo stacked unit Model # 417.92702200 will not drain it has noise and runs thropugh the cycle then spins like it should just will not drain out water after its done wash cycle....
looks to me that you have eather coins, yes,coins traped in the electric water pump mostly a quarter blocking the inlet of pump or a piece or clothing from the hose that comes from the bottom of the OUTER TUB to the PUMP. if not you may have a faulty pump.
good luck to you.
Feb 07, 2011 | Kenmore 22422 Top Load Washer
Kenmore laundry center stacked washer/dryer washer tub shakes almost violently on spin cycle.I may have changed setting during spin cycle.Tub is off balance.The appliance cabinet is balanced and on a solid...
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2009 | Kenmore Washing Machines
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
614 people viewed this question
Sal De
fordexpert
Robert Rankin
