Question about Garden
When I finish mowing yard I disengage mower blades but they keep on turning why
    Problem Solver:
  • 8 Answers
If this mower has a manual lever that has to be pushed up in order to engage the blades then check the tension pulley that connects to the lever cable on the top of the deck,it probably need to be lubricated or cleaned in order to move freely back to the normal position.
Posted on May 18, 2010
Blades disengage
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 22, 2016 | John Deere Garden
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
I have a mountfield 1538h-sd blades disengaged while mowing belts seem very slack ,but the belts are all on the pulleys.
The belts may be loose.With the mower off,engage the blades and check the tension.Next would be to get under the mower and check for debris in and around the lever that engages the blades.Sometimes trash will get hung up in there and the blades will disengage.The next step would be to inspect the pulleys for debris and to make sure the spindles are not bent.While at the pulleys make sure there are no burrs or cacks in the pulleys,as that will cause the blades to disengage.
Jun 03, 2011 | Garden
I cannot disengage the cutting attachment so that the mower will start; it seems like it is stuck, because when I attempt to disengage the blades the lever will not move into the disengaged position. How...
You haven't specified the model number, but pretty much all riding mowers use a plunger-type electrical switch to engage the mower. If it's stuck in the 'lifted' position (mower engaged) then it has broken internally. You must replace it. In doing that, the wires need to be placed back on the correct terminals, so take a picture of the wires (showing their colors) before you disconnect them from the switch. Take the broken switch to a lawnmower shop to find a replacement. Shouldn't be more than $10 - $20. Good luck! Please rate my solution if you found it helpful.
Jul 03, 2010 | Craftsman Garden
Mower will not disengage
this is because your belt that drives the blades is to tight i suggest getting a looser belt
May 10, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
338 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
