Question about HP LaserJet P3005n Printer
Describe your hp p3005 sleep mode Problem. Printer will not wake from sleep mode to print network job
Nikhil Gedam
  • 87 Answers
SOURCE: HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Posted on Nov 21, 2008
SOURCE: Network Printer Problem
In the later HP LaserJet printers the printer has a "Mopier mode" that will provide better print performance on multiple copies. However, if you have "Mopier mode" enabled and you don't have an EIO hard disk installed, you'll get the above message.
Right click on the printer, select "Properties". There should be a "Device Settings" tab. Under that tab, make sure that "Mopier mode" is Disabled at the bottom.
The unit will still print multiple collated copies with that disabled.
Posted on Jan 21, 2009
  • 217 Answers
SOURCE: my printer go to sleep mode and never wakes up
It is a well known problem. You'll have to exchange the formatter board.
For a P3005 its partnumber: Q7847-61006, for a P3005N use partnumber: Q7848-61006. Good luck, Gerrit Jan
Posted on Oct 30, 2009
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
SOURCE: my officejet pro 8500 will go into a sleep mode.
Here's what HP had to say about mine:
1. Print out a self-test page and check your firmware version.
Compare your version to this web page:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-82657-2&lc=en&dlc=en&cc=us&os=4063&product=3752456&sw_lang=
If your version is different, upload the new firmware in accordance with the directions provided.
If your version is the same, go to these steps:
1. On your printer, press * and # simultaneously
2. Press 1, 2, and 4, in that order. (This sequence should be the same for yours, too)
3. Select the underware menu (I know, sounds funny)
4. Select the System Menu
5. Select System Mode Time Out (you may have to scroll for a few screens)
6. Set this to 0, press OK
7. Turn Off/On Printer.
I just reset mine this morning and will find out tomorrow whether or not this is the fix, but it seems to be so far.
best of luck!
Posted on Nov 22, 2010
Wi-fi does not turn printer on
If you are referring to the printer not waking up when sent a print job then check the sleep settings as on many HP products you can set what type of jobs will wakeup the printer, such as USB or network. As you do not state the model I cannnot be more specific.
Oct 16, 2014 | HP Office Equipment & Supplies
Turn off sleep mode
Print a menu map from the control panel
Mar 21, 2014 | HEWLETT-PACKARD CP1025nw Laser Printer
Printer not responding hp photosmart 6525 after going into sleep mode
My printer will not print after sitting for about 30 minutes. As soon as I turn it off and then back on the job I previously sent, prints out. I tried changing the amount of time before it goes to sleep but this does not correct it and does not seem to be related. You can hit the check mark to wake it up but it still will not print until turned off and then on. Source: How do you turn off the sleep mode in a HP 3600 printer?
This is the only solution is see and it didn't solve the problem
Nov 30, 2013 | Office Equipment & Supplies
Laserjet 1536dnf mfp not waking out of sleep mode
Disable sleep mode or update firmware. Cause this is a firmware bug.
Nov 13, 2013 | HP Laserjet M2727nf Multifunction Printer
My Hp laserjet p3005 drops offline and cant print, any help
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Sep 06, 2011 | HP LaserJet P3005 Printer
Have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
Power Save Mode.Just press the on/off button or wait for the printer to wake up when you start a print job.
Nov 07, 2010 | HP Officejet 6500 Wireless All-in-One...
My printer go to sleep mode and never wakes up again, why???
Oct 29, 2009 | HP LaserJet P3005 Printer
Mar 25, 2009 | HP LaserJet 3600n Printer
Hello
Issue
Solution
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
HP LaserJet P3005n Printer Logo
363 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
