Question about GE GSH22SGRSS Side by Side Refrigerator
My water is not comeing out from the door any more it come from the connection at the bottom
    Problem Solver:
  • 3 Answers
Pull the Refrigerator out from the wall, pull off the main panel at the bottom and check to see if the tubing is still connected at the quick coupling. You have the main waterline coming in then it splits to the red and blue fittings. One goes to the water filter and dispenser and the other to the ice maker. I had the same issue which I found my tubing had dry rotted at the curved part and actually had several cracks in it. Fortunately there was enough extra tubing that I could just slide it back up into the coupling. Immediately you should hear the water run through it. I would suggest running a couple of gallons through when reconnected depending on how long it's been broke and maybe even replacing the filter.
Posted on Oct 24, 2010
LG Dishwasher leaks!! New E1 Code just fixed an HE Code, gasket not broke, one of the electrical connections underneath had come loose so I just clipped it back on. I have not hooked everything up again...
http://lgdishwasher.yolasite.com/ MINE JUST STARTED AGAIN TODAY. SWOLLEN BOTTOM DOOR GASKET LOOKS LIKE HILLS UP AND DOWN. ALLOWING WATER TO OVER FLOW DOOR BOTTOM. GETS TRAPPED BEHIND GASKET. PAN HAS LITTLE WATER WHEN YOU OPEN DOOR. BUT CAN SEE RUN OUT OVER EDGE WHEN RUNNING WITHOUT OUTER DOOR SKIN, ALSO LEAKS AT TOP CORNERS DUE TO DEFORMED CORNER GASKET. THEY SHOULD HAVE MADE THE GASKET ROUND IN CORNERS TO KEEP IT SEALING, HAD TO MAKE C METAL CLIPS 4 INCHES LONG TO HOLD BOTTOM GASKET TIGHT TO BOTTOM PAN, USED 4 CLIPS AND TWO SMALLER AT ENDS
Oct 18, 2013 | LG LDF6810ST Stainless Steel Built-in...
How to remove freezer door with water/ice dispenser on GE profile TFH22PRSM
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
Jan 17, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire professional series refrigerator leaking water under door
Hello - Typically when water is coming out from under the refrigerator there could possibly be a loose connection from the house water supply line to the water valve or a cracked drain pan (located underneath the refrigerator). Try confirming that the valve is tightened. If the connection is still leaking, turn off the water supply valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. There could also be a loose water connection to the door. This connection is located on the bottom left of the freezer door.
Sep 25, 2012 | Frigidaire Professional Series PHS68EJSB...
No water will come out of the door
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
May 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water in door is not coming out very much intermiient
There is a mesh screen filter in the water supply line where it connects to the water inlet valve on the back of the unit. You can disconnect the line coming out of the valve and try the dispenser to see if it comes out normal. You can disconnect it at the bottom of the freezer door to see if it comes out normal there. If it does the water could be freezing in the door. Leave the door open till it thaws out. Cover the freezer with a blanket to prevent loosing too much cold air.
If you have a water filter it could need changing.
Nov 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Washer leaks water
If this leak is coming from the front door, replace the door and drum seal. If this leak is coming from the bottom or rear bottom area, this will be a loose drain hose or, faulty inlet water valve assembly connection.
Inspect these areas closely.
Jun 25, 2009 | Kenmore Washing Machines
Water leaking
there should be a quick disconnect about 4 inches from the bottom of the door. look behind the toe kick. if it leaks from the disconnect try pushing the plastic lines into the disconnect. the disconnect is about 1.5 inches long and should have red or blue ends. to get the lines out you push the colored ends in while pulling the plastic line out, try cutting off the ends smooth and straight up and down and re-insert. if the water is coming out of the bottom of the door you need to replace the water line in the door.
to get the line out of the door. use a flat blade screwdriver to pry the dispenser cover off the door. there are two slots on the bottom of the dispenser facia. use a pen or something hard for a pivot point and use tape to protect door finish. push on the screwdriver until you think the plastic will break, then push a bit harder and it will pop off. now you can disconnect the facia and remove the screws holding the switches etc. disconnect the water line and pull it through the dispenser. to put the facia back on just hook the top and line it up and press the bottom back on.
May 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
How do I remove the doors?
Refrigerator side is easy. Remove the top hinge cover and then the hinge. Lift it off the bottom hinge and set it to the side. The freezer side is a little more entailed as it has a water and electric connection. Remove the lower kickplate (Grille) and then you will see a plastic tube coming out the bottom of the hinge. Follow it to the connector and removed it. A little water might come out but it will stop. Next, go to the top hinge and remove the hinge cover. Unplug the electric connection and then remove the top hinge. Lift the door off the bottom hinge sliding the plastic tubing through the hinge...This should do it. If you need further asssistance, we are here.
Eric Campion
Feb 21, 2009 | Frigidaire FRS23KF7AB Side by Side...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Aug 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
GE GSH22SGRSS Side by Side Refrigerator Logo
192 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
