Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
I have a MLG200AWW that stops mid cycle, turns
I have a MLG200AWWMaytag Neptune stack washer that stops mid cycle turns off and unlocks. Help! The machine was bought in 2002 and had the recall repair done in 2005. A repair man just replaced the washer timer and we still have the same problem. If you move the dial a tad and push the on button again it will start again. Sometimes it will finish the wash sometimes it repeatedly stops unlocks etc.
  • 90 Answers
SOURCE: stops between cycles
sounds like a bad motor control board. It is located at the front rt bottom and will probably show a burnt spot in it or the fuse will be blown. You must replace motor kit.
Posted on Jan 05, 2008
vest6
  • 196 Answers
SOURCE: Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Posted on Jan 15, 2008
  • 409 Answers
SOURCE: Maytag Neptune front load will turn on then off in 3 seconds....
hi there,
please supply the full model # on your washer.
Posted on Sep 15, 2008
  • 157 Answers
SOURCE: starts and stops during wash
Hello fx1360. From your info the timer is sticking. You will need to unplug AC power first, if you don't have enough room behind the unit you will turn off the water facets and disconnect the hoses. Remove the back panel to the control housing. Before you disconnect any wiring make notes what color wire went where. Remove the knob and mounting screws to remove the controler. Now it is desion time. Option #1- note model & serial#, find a applance repair shop & get a replacement. If Mr. Budget says NO! Option#2- open the the housing of the control & clean the contacts with a burnising tool or emory fine grain sanding paper. This step will be like a watch repairman. Your brushes are worn down or your cam has worn down or the gears driving the cam are worn down. Good Luck.
Posted on Oct 02, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Posted on Mar 20, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune TL stops spinning mid cycle? The washer stops with 11 to 13 minutes from the end of the wash cycle and leaves water in the wash tub. We've tried shifting the load for balance but it does not...
RF_Tim
I feel you have a Clutch malfunction a very common problem with the machine. If you want to DIY the fix see my Clutch Fix post.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you need some additional help just shout back……..Rich
Jun 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Stops mid cycle, won't spin
You need to check and see if the door-lock light is on ,if not then you have either a faulty door lock mech. or a defective solid state board in the control panel
Dec 27, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
