Question about Canon PIXMA iP3300 InkJet Photo Printer
Printer problem, yelloow head not working on my canon
I have a Canon Pixma IP3300 printer. Whilst printing a page the yellow ink stopped printing. The yellow ink cartridge is new and full, and i did a deep head clean and personally checked the cartridge myself. All three other colours print well.
  • chinche Aug 24, 2008
    i had the same problem. couldn't figure out what was wrong so decided to get new yellow cartridge-- and it worked.
    New Friend:
    Problem Solver:
  • 5 Answers
I stumbled on an ebay seller who is selling cleaning solution for print heads. Canon print heads are removable without special tools.
I gave mine a clean with metho, as I figured that it could not get any worse and I got the gist that I was going to have to replace the printer anyway.
I cleaned it with metho (just the bottom of the print head) and ran the clean print head function twice from maintenance and it is not working perfectly.
I do recommending taking this advice with caution as I do not know if this process could cause further damage or not work.
Posted on Nov 28, 2009
?¿?¾?¿???¾?±???¹ ?¼?¾?¶?µ?? ???°???????¸?´?¶ ?½?µ?¿?»?¾???½?¾ ?²????°?²?»?µ?½ ?¸ ?¾???¾???µ?», ?±???²?°?µ?? ?¸?· ?·?° ?¿?»?¾???¸?? ???µ???½?¸?», ?¼?¾?¶?µ?? ???°???µ?????° ?¿???¾???¸??????¸ ?½?µ ?¿?¾?´??°????²?°?µ?? ?????°?????, ?¾???½?µ??¸ ?² ???µ?¼?¾?½?? ?µ??»?¸ ?????¾, ?¼?¾?¶?µ???Œ ??½????Œ ?³?¾?»?¾?²?? ?¸ ?¿???¾???µ???µ???Œ ???¸???????¸?¼ ????µ?´????²?¾?¼ ?´?»? ?¿???¸?½???µ???° ??°?¼?? ?¿?µ???°???½???? ?´?Ž?·??
Posted on Jun 08, 2008
SOURCE:
My canon pixma ip3300 printer black ink can recognize but when printing no black ink out
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jan 19, 2012 | Canon PIXMA iP3300 Printer
Cannot print black color in iP3300 Cannon printer and all the ink are full.
The printer head is my be block. In these situation you need to wash the printer head with cleaner., and the same time push some amonia solution with the seringe through the black ink output pin gentaly. Then re assamble and turn on the printer .
I think You may rid from your problem.
Thank you.
May 19, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
My Canon Pixma ip3300 prints on top of an absolutely perfect printing, a sequence of stripes colored in magenta, the stripes are 2,7 mm wide and are 2,7 mm apart from each other. All other functions of...
try to clean the ink print head cartridges also its trailing (belt, pulleys) you can reach. a dirty ead may cause that or better check it to printer solution software, there you can test, align, clean printhead.
Feb 12, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
I HAVE LINES APPEARING ON COLOURED PRINTS
try cleaning the head with window cleaner and dry the head thoroughly
Jun 05, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
PIXMA iP3300 InkJet Photo Printer: my canon iP3300 has an alternately flashing green ...
I may be that your printerhead passed away. A replacement might do the trick.
May 07, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip 3300 flash 5 times orange
pixma ip3300 flash orange 5 times, i remove all catridge / remove print head and orange flash 5 times. help!!!
Sep 18, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
How to reset waste ink absorber full ip3300 warning?
Try to enter service mode and reset EEPROM:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head
Press RESUME 4 times then POWER to execute the command
turn the plug off turn on and all ok
Dec 13, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon Pixma 1P1600
printer driver canon PIXMA iP1600
Oct 08, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
138 people viewed this question
Clive
Clive
old marine
old marine
Ekse
