Question about HP DG937A - HP Tablet PC TC1100 Tethered Pen (DG937ATABLETPEN)
How do i change the batteries on my tc1100? - HP DG937A - HP Tablet PC TC1100 Tethered Pen (DG937ATABLETPEN)
Can i get help with my tc1100
The official site for download of all TC1100 tablet pc is available at this link.
HP Compaq tc1100 Tablet PC
These drivers are compatible only for Window XP. If you are trying Windows 7 then you will have to take a chance. It may or may not work.
See this article.
HP TC1100 Windows 7 Installation Notes
Sep 23, 2014 | HEWLETT-PACKARD HP Compaq TC1100 Tablet PC...
HP tc1100 power issue
Go to ebay and search for "tc1000 charger". You'll be able to find one for 10 at the most with free shipping most the time.
Nov 28, 2013 | HEWLETT-PACKARD Hewlett Packard 348349-001...
Power switch of HP Compaq tct 1100 Tablet PC
http://www.jksalesinc.com/catalog/images/TC1100.jpg
heres wat u need, go to the above link..
Nov 03, 2009 | Compaq Tablet TC1100: Tablet TC1100 P-M...
TC1100 SOUND PROBLEM
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers
Jun 30, 2009 | Compaq tc1100 Tablet PC
TC1100 does not turn on!
Check the wall outlet to be sure it is providing power. Use a lamp or a fan or other electrical device to be sure that outlet provides power. Check the power surge supression strip, and ensure it is switched on if it has a switch, and it it has a fuse reset button, push that in or push it to the reset position. Recheck the connection of the wall connector cable to the small DC converter box. Finally recheck the connection of the end of the power cable where it connects to the PC. If the Tablet still does not show a green light indicator on the front, try removing the battery. The TC1100 works with the battery completely removed. If you have power but no display, then the problem could be with the display. I suggest that since there are a lot of problems with the older tablet PCs, that if you still have problems with it and do not really need that type, check out the new low priced Atom processor netbooks and the new moderately priced Intel Core2 Duo notebook PCs and AMD dual core and tri-core notebook PCs, with plenty of RAM like 2GB or more, and preferably dedicated video RAM, like an NVideo or ATI video that provides 64MB or 128MB or 256 MB or 512MB or more of dedicated video memory. Back to your TC, ensure it has good power, then look to possible bigger issues that power or power adapter - the CPU or board could be bad, or it may boot up but not display because of a problem with video on board or in the connector to the screen or in the screen circuitry.
Mar 08, 2009 | HP 303178-001 Compaq TC1000 TC1100 Tablet...
HP TC1100
Try plugging in the tablet with the battery not installed. If there is no battery the tablet should turn on with just the AC adapter. If that works there might be a dead short in the battery and you would have to replace it
Jan 27, 2009 | HP DG937A - HP Tablet PC TC1100 Tethered...
Change ID,servicetag and asset tag for HP TABLET TC1100
you can change both of those in the bios which you get to by tapping either del key or f1 or f2 key one not all it will have them just edit hit f10 to save
Jan 25, 2009 | HP Compaq d530S PC Desktop
TC1100 checkered screen
Could be a bad ram chip as video uses the system board ram for video. You will have to crack the case and swap the ram for a known good stick. Be very careful!
Unfortunately the onboard video card may be bad, usually the problem.
I could crack it and check it for you, you pay shipping. I have the RAM.
Contact me at brianrosshill@aol.com with "TC1100 repair" in the subject line.
I love the machine and you shouldn't have to pay a fortune to get an opinion.
I don't offer this service to any other group, machine or etc. Just the tc1000 and tc1100.
I'll answer your email and suppl contact info. I've been into several of these machines, no worries Mate.
Central Missouri, USA
Sep 20, 2008 | Compaq tc1100 Tablet PC
Compaq tc1100
You use Q-Menu to turn on or off WLAN. Go to HP and download/install Q-Menu:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=376810&prodNameId=376812&swEnvOID=1059&swLang=8&mode=2&taskId=135&swItem=PSG_I22141-106467
Aug 20, 2008 | Compaq Tablet TC1100: Tablet TC1100 P-M...
Hp tc1100 memory location
If you flip your laptop over, make sure all power is turned off and the battery is out, Now look at underside of machine there should be one or two screws in a square cover, Just remove the screw or screws and take cover off, Now the modules are held in by two white or black tabs on either sides of the sticks, Just push the two lock down clips and the module should pop up, Pull straight back out and remove. Now when u are replacing with the new ones make sure they are the same speed. and better yet make sure its a matched set, and put back in the same way as they came out in reverse order. Make sure when you push them back into there slots that they are snugg and firm into place, Put battery back in hook power up and reboot you Hp. It should tell you there has been a memory change and ask you to push enter or any key to except and you are on your way to more memory, Thanks for looking and Happy Holidays To You And Your Family
Dec 12, 2007 | Compaq tc1100 Tablet PC
HP DG937A - HP Tablet PC TC1100 Tethered Pen (DG937ATABLETPEN) Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
