Question about RTO 7 X 12 1HP Turn Pro Band Saw
I have a model 01712041 7*12 Turn-pro metal
I have a model 01712041 7*12 Turn-pro metal cutting band saw. The quick adjust nut on the vice is worn out. Are there replacements. Thanks
3 Suggested Answers
  • 4088 Answers
SOURCE: I have a model 01712041 7*12 Turn-pro metal
Take the part to a local machine shop for rebuilding or construction of a new component. Take the entire vise with you if possible so that they can see what is wrong and perhaps provide an improvement. Hope this helps!
Posted on Jun 25, 2010
That saw is sold by Enco. Phone 1-800-873-3626.
Part # is 172-2385 for the nut assy. $36.75 + shipping as of 4/12/12
Ed
Posted on Apr 12, 2012
How do I adjust the tension on the saw blade
there is a slide adjustment on the top roller
It is used when replacing broken bands or bands of different teeth numbers
undo the lock nut and screw the adjustment knob until the band "twangs " when flicked
do the nut up tight
Feb 15, 2016 | Ryobi Owner's Manual Model Bs901 Bs902...
How long is replacment blades
Blade length is 93" or 7'9" . I get my blades from sawblade.com , I use bi metal 10-14 blade for cutting steels.
Jul 08, 2014 | RTO 7 X 12 1HP Turn Pro Band Saw
Mbs45 blade undercuts out of square, twist in 2x2 1/8" tubing
I believe Black bull band saw is a Taiwan imported saw. They are even cheaper to HF band saws. This band saw have so many issues; make sure you align the guides, tune it up and use good bi metal band saw blades. I suggest you use the Haltbar 601 bi metal blade. I'm using Haltbar and I'm getting really nice cut.
Jun 18, 2014 | Buffalo Tools Black Bull Metal Cutting...
What makes a delta 28-243F 14" band saw blade keep coming off?
The most common is wheel misaligment. The top wheel has an adjusting screw or the equivalent somewhere, and you can turn that to align the blade to the center of the wheels.
Second most common is guide problems. There are some guides that are supposed to hold the blade "just right" above and maybe below the table where you are cutting These must be set to support the blade in it's correct position as you are cutting through the material you are cutting.
3rd problem is a saw blade that has lost it's tension from being
" worn out ".
Be blessed.
May 20, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Blade drift with Milwaukee bandsaw
Worn band saw guides maybe? Or too much tension or change the blade , I use bi metal Haltbar band saw blades of sawblade.com
Mar 26, 2014 | Milwaukee 6238 Deep Cut Portable Band Saw...
How do you line the blade on a shopfox m1014 it wont cut stright
You should check your manual for correct blade tracking adjustment. Place the guides properly. You should use a fine
blade as well. I have 7x12 band saw and I am using Haltbar band saw blade on it. I got it on sawblade.com . The blades
are really good.
Mar 27, 2013 | Shop Fox Metal Cutting Band Saw 7in. x...
How do I change the blade on my pro-tech model 3104 bandsaw
Before doing anything, check the length of the blade. You maybe have the wrong length.
It may not tracked and tensioned properly. Double check the adjustments.
Are the tires new? Tires should not be worn out. Guides must be positioned properly too.
You may want to check your manual. It can help to figure things out. And oh , try reading this
blog : http://bandsawblog.com/replacing-the-band-saw-blade-on-your-band-saw/ .
And you can check more informative blogs there. Hop[e I helped you.
Jan 18, 2013 | Saws
What do i need to do to adjust the tension on my Delta 14" band saw
IN THE TOP COVER THERE IS A ADJUSTMENT NUT,KNOB OR SCREW. TRICK IS NOT TO OVER TIGHTEN IT. WHEN CUTTING THE BLADE SHOULD NOT WANDER. THAN THAT'S PERFECT .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 25, 2011 | Delta 28 640 20" Single Phase Wood Cutting...
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
Ed
Mar 25, 2010 | RTO 7 X 12 1HP Turn Pro Band Saw
RTO 7 X 12 1HP Turn Pro Band Saw Logo
80 people viewed this question
Top RTO Saws Experts
john h
David Hoff
Mike
Are you a RTO Saw Expert? Answer questions, earn points and help others
