Canon PowerShot S2 IS Digital Camera Logo
A
Anonymous Posted on May 14, 2010
Camera won't show anything but black in the screen ... Or looking through the eye piece (canon S3 power shot) think the cold weather caused it
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on May 16, 2010
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1195022
Points
12483
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Black screen for Shooting Canon S3 I
Your camera has a stuck shutter. There is a guy on eBay that fix this issue for a low price. Fix is for Canon S2, S3, S5 with stuck shutter. here is the link in case you need: http://www.ebay.com/itm/141414188140
3helpful
2answers
Black screen on my canon S3 Si camera
This sounds like a common image sensor failure. Unfortunately Canon stopped fixing this problem over a year ago. Parts are NLA.
Nothing displays on screen
Most likely the shutter is jammed shut - this is commonly due to heat causing the oils in the lens to evaporate and then condense on the shutter blades.
The camera will need to be serviced, and this oild cleaned off the blades. Well worth doing, as these are great cameras :)
1helpful
When I turn on my camera the LCD screen is balck and I cant see anything thruough the lens. It does take pics because when I upload the disck Ic an see the new pics
Double check if the viewfinder is operable (not the LDC but the little thing you look through with one eye above it). Try pressing the display button to flip through the different modes as you're looking through the viewfinder. If the viewfinder does work (and the LCD screen doesn't come on as you're scrolling through the modes) then it is most likely dead (broken). If the viewfinder works, you're can still use the camera otherwise it's probably time to get a new one.
The lcd display does not show picture
You should remove the lens and see if the mirror is stuck in the up position.
1helpful
Black screen for Shooting Canon S3 IS
I have a similar problem with my Canon S3 IS. Dark/black LCD in Shooting mode. However, I can view my existing photos in Display mode. I was about to spend money to get a Panasonic TZ5. Somehow I bumped into a solution post for S2 IS. Here is the link:
http://www.fixya.com/support/t1090569-black_screen
I tried their solutions twice and it WORKS. My S3 is working fine now.
My screen went black after i took a picture
It's very possible that the problem is that the shutter is stuck, which is a known Canon issue on the powershot cameras, mainly on the S2 and S3 models, which it happens after some time (weeks or months) thata camera is not used.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires the skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S3".
Best regards,
3helpful
Black screen when taking pictures
Best regards,
Need Parts
call canon they will sell to you goto www.canon.com
10helpful
6answers
Canon S3 no display on LCD screen
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
