Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer will not drain.
Tt fills and agiates but does not drain. After agiation(any cycle setting) it just sits there and does nothing. The cycle doesnt complete.
  • Whirlpool Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinewasher will not drain. - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
Started doing a load of landry with mt whirlpool imperial model number LSQ9244EQO, will fill, agiate, but stops which will not drain or spin, ideas?
Arthur, We are sorry to hear that your Washer is not completing a cycle. Please check to make sure that there are no kinks in your drain hose. We also would recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Washer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
May 29, 2017 | Whirlpool Washing Machines
Kenmore washer 80 series will not agiate
What is the model number of your unit?
Nov 25, 2012 | Washing Machines
Washer fill with water model # LA4800XTW0 then just sits there no agiate no spin water will then drain once switch is manually advanced. Lid switch problem? OR direct motor coupler?
Hello, welcome to FixYa.
Based on your post, if you mean manually advancing the timer it will drain, it's a coupler. If you mean manually activating the lid switch, it is the lid switch or lid switch strike.
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...based on the model provided, it cover's yours)
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Whirlpool Washing Machines
Washer will not agiatate, makes funny noise, will not spin
transmission sounds like its gone bad, will it spin, if it does it mite be ur timer
May 22, 2010 | Whirlpool Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Roper washer will not agitate
could be the transmission or the drive motor to transmission coupling. You say the agitator doesn't work but it washes fine please clarify your problem.
Jan 12, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
1,201 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
