Question about Dryers
Do you hook up a steam dryer to the hot or cold water?
3 Suggested Answers
  • 494 Answers
SOURCE: I need the installation manual for a Kenmore Elite
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Posted on May 18, 2010
KevinWhite
  • 1902 Answers
SOURCE: I have a brand new
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, as it is under warranty then you can use it to get the part replaced. Please get back to me if you have any other questions.
Kevin
Posted on Sep 13, 2011
My clothes came out hot and steaming after a 40 degree wash? It's not a washer/dryer.
you have a water inlet problem then possibly hoses hooked up backward hot on cold and cold on hot
Mar 19, 2015 | Indesit Washing Machines
We have a Oasis Washer and Dryer with 4 hoses 1 is a Y trying to figure out how it all hooks up as we have only had 2 hoses in the past 1 for hot and one for cold???
If you purchased a steam dryer then the one hot hose hooks to the dryer. The cold hose goes to the washer. The hot hose from the valve goes to the Y then one hose to your washer and one hose to your dryer
Jul 11, 2011 | Kenmore Washing Machines
Water pouring out of cold water connection the hookup is only connected to the hot water because the steam hookup is suppose work for hot water.... So they say??????!!! Is there suppose to be another hose...
YES YOU NEED TO EITHER PURCHASE A SCREW ON PLUG FOR THE COLD SIDE OR HOOK UP A HOSE FROM A COLD WATER VALVE TO THE COLD SIDE OF YOUR INLET WATER VALVE ON THE WASHER (YOU SHOULD HAVE GOTTEN A HOSE WHEN YOU BOUGHT IT, IF NOT YOU CAN PURCHASE ONE AT YOUR LOCAL HARDWARE STORE OR APPLIANCE PARTS STORE , OR SEARS PARTS DIRECT. LET ME KNOW IF THIS WAS HELPFUL!
Mar 10, 2011 | Frigidaire Washing Machines
Reinstalling a washer and dryer and i know which line is hot and which one is cold coming out of the washer ing machine but i dont know which line is hot and which is cold when hooking it back up the the...
If the pipes were installed properly, then the hot is on the left, cold on right.
Hook it up that way, then set it on the smallest load possible, with hot water setting only. If you have hot water filling the basin, you have it hooked up properly.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Hook up
this one is simple. first connect the hot water hose to either inlet. now turn on washer for cold water only. if no water enters machine, you have it correct. now connect cold water to other one. now repeat cold water wash...does water come in?
Aug 17, 2007 | GE WSM2780W Stacked Washer / Dryer
Open Questions:
Dryers Logo
288 people viewed this question
Top Dryers Experts
