Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Model she44 won't drain
We have Bosch model SHE44C05UC. It won't drain and it stays on 1 minute(never finishes cycle) Filters are clean and took cover off impeller and it moves freely. Any way to find out an erro code or any suggestions? Thanks
  • Bosch Master
  • 2,605 Answers
Hello, welcome to fixya.
I see you posted this question/request for assistance to your problem a week ago, sorry no one has been able to assist you, hopefully I can now.
The reason your dishwasher is displaying a "1" is the control has detected a heating error. The error code is displayed by the number "1". Here`s the most likely reason why it has detected the error...
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Posted on May 22, 2010
Bosch washing machine - electronic timer goes down to 1 minute remaining and stays there. Washing liquid has been drained from drawer, however, fabric softener is still there. We have resorted to stopping...
Check if drain filter is clear and drain pump is working properly. Also remove soap conditioner tray and check if you have black residue inside the soap/conditioner dispenser. Sometimes this can prevent water from entering the conditioner tray.
Oct 24, 2013 | Bosch Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 25, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher doesnot drain
Once you ensure that the drain lines are clear, this usually means that the drain pump is stuck, clogged or faulty.
Try first unplugging power cord for ten minutes.
If this does not help, the pump is clogged or defective.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
706 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
